Personally I would hold out for the 40803080Ti will be out soon![]()
More likely to get one of those!Personally I would hold out for the 4080
mm interesting. don't know who is bigger (san or PCS) but if scan is getting some, you would hope PCS is getting some as well.I ordered my machine 28th September 2020.
Currently at 51 working days of production time and still in pre-production.
I think it depends what 3080 you've ordered as to when you receive your order because we may be in different queues. I ordered a ROG Strix - I've found no evidence of anyone receiving one of these and I've tried in vain to speak to PCS about swapping it out.
Fundamentally I do not understand why PCS can't publish a queue. Scan seem to manage just fine and I bet it has dramatically reduced the burden on their customer service teams.
NVIDIA 30 Series Launch Status
FAQs and deliveries on the NVIDIA 30 Series launch eventswww.scan.co.uk
P.S. lolz @ arachnophobe
I also use Scan as a proxy.mm interesting. don't know who is bigger (san or PCS) but if scan is getting some, you would hope PCS is getting some as well.
I would hope to see a pattern when people go in building in batches. i.e. nothing happening for a few days and then 50 or more (hopefully not less) machines are starting to be assembled and so on.
which I guess we can only find out on this forum at the stage.
Did you specifically order a Strix OC? I couldn't see it as an option.I have received my PC with a 3080 Strix. 24th September ordered, arrived 23rd November. It is an OC version so not sure if that makes/made any difference to people who ordered non OC builds.
How do you know where you are in the queue? They tell me it's impossible to say.Ordered: Stock Asus 3080 / 5900X
Order Date: 05-11-2020 14:16
Pre Production: 24 Days
Place In Queue:199th then moved up to around 200+ when i called on 7th Dec (not sure WHY) CPU and GPU not in stock
Harsh. Maybe your 5950X is causing issues because Scarpa1 ordered after you but has received his PC already. Or maybe it's down to the OC/non-OC version.Ordered on 20th September and still waiting...
Switched from STRIX 3080 to standard and have a 5950X.
It’s not the 5950X as that’s in stock. Think Scarpa1 has a liquid build? Mine is just your standard machine.Did you specifically order a Strix OC? I couldn't see it as an option.
Liquid Series builds are all OC, from what I've looked atDid you specifically order a Strix OC? I couldn't see it as an option.
Yes mine is a liquid series and a OC strix 3080.It’s not the 5950X as that’s in stock. Think Scarpa1 has a liquid build? Mine is just your standard machine.
Yes they areLiquid Series builds are all OC, from what I've looked at
Unless of course Curry’s have an order in for 300 PCs that need 300 GPU’s then one order to one gpu goes out the window.Hey all
not that it matters but for whatever reason the stat that PCS has about % of completed orders within an x amount of time under the "your orders" list, seems to be updated on a regular basis. For whatever reason that is linked to their internal software.
I do not know if there is a delay to it, but it was at 88% the other day and now it is at 90%.
Truth is that if they get 100 odd GPUs a week (which I am not sure that is the case) and there are 1000 people in a queue then that is 10 weeks i.e. 50 working days.
