I ordered on the same day and I’m still in pre production.30th of last month.
Worth giving a call, maybe some other part is out of stockI ordered on the same day and I’m still in pre production.
I emailed them about it and they said that some of the parts were out of stock but were being delivered this week.Worth giving a call, maybe some other part is out of stock![]()
That sounds good. But as I said, I would have called and asked them which parts are out of stockI emailed them about it and they said that some of the parts were out of stock but were being delivered this week.
It is quite annoying that they are so vague as to what parts are not in stock right now. I would happily change my order to stocked parts if it meant it would be built quicker.
They said they were out of the 5600x and the 3060That sounds good. But as I said, I would have called and asked them which parts are out of stock![]()
I personally wouldn’t, just sit back and relax.Is there any point in even ringing them to check up on the order? I asked them how far I was in the queue and they told me it would be a few weeks and maybe even a few months for my build to be delivered. Every time I talk to them I get a different answer and it is just needlessly stressful.
Would you mind posting your spec? It might be another component holding your build up. 40 WD certainly seems longer than some of the other recent 3060 orders.I'm on 40 working days now, I phoned last week and they said they had the stock to build mine but I don't know how true that is. The wait continues![]()
Case | CORSAIR iCUE 220T RGB AIRFLOW MID TOWER GAMING CASE |
Processor (CPU) | Intel® Core™ i9 Ten-Core Processor i9-10850K (3.6GHz) 20MB Cache |
Motherboard | ASUS® ROG MAXIMUS XII HERO Wi-Fi (LGA1200, USB 3.2, CrossFireX/SLI) - ARGB Ready |
Memory (RAM) | 32GB Corsair VENGEANCE DDR4 3600MHz (2 x 16GB) |
Graphics Card | 12GB NVIDIA GEFORCE RTX 3060 - HDMI, DP |
1st Storage Drive | 2TB SEAGATE BARRACUDA 120 2.5" SSD, (up to 560MB/sR | 540MB/sW) |
2nd Storage Drive | 2TB SEAGATE IRONWOLF PRO 3.5", 7200 RPM 128MB CACHE![]() |
DVD/BLU-RAY Drive | NOT REQUIRED |
Memory Card Reader | USB 3.0 EXTERNAL SD/MICRO SD CARD READER |
Power Supply | CORSAIR 850W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET |
Power Cable | 1 x 1 Metre UK Power Cable (Kettle Lead) |
Processor Cooling | Corsair H60 2018 Hydro Series High Performance CPU Cooler |
Thermal Paste | STANDARD THERMAL PASTE FOR SUFFICIENT COOLING![]() |
LED Lighting | 2x 50cm ARGB LED Strip |
Sound Card | ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD) |
Network Card | 10/100/1000 GIGABIT LAN PORT (Wi-Fi NOT INCLUDED) |
USB/Thunderbolt Options | 2 PORT (1 x TYPE A, 1 x TYPE C) USB 3.1 PCI-E CARD + STANDARD USB PORTS |
Operating System | Windows 10 Home 64 Bit - inc. Single Licence [KUK-00001] |
Operating System Language | United Kingdom - English Language |
Hope you get it soon manAs of today, i have ordered my pc with a 3060wish me luck!
Thanks mannn!Hope you get it soon man
ayyy lets gooo, whats the specs u went with?We've ordered one as well on the 7th! 😁 so fingers crossed!
It's mainly going to be used for work (I'm a graphic designer, my partner a video editor) and some games here and there as well, I've had a friend help me out putting this together as I'm completely out of my depth haha. We already have a 2tb SSD here as well that I need to put in, and we have a NAS drive for work files. Burt yeah I'm so excited!!ayyy lets gooo, whats the specs u went with?
