Deleted member 17413
Fractal Define 7 isnt a gaming case, its a quiet build case...and has very good thermals for a case like that/with soundproofing.
You might use it for things like audio recording etc.
Far as I was aware, you can still choose to send in your own case.
You need to be careful about if its will fit though, so check things like fan capacity and dimensions to ensure GPU can fit and stiff like that.
