I wouldn't order a default fan, they're very low quality and loud.Extra Case Fans
If you have already ordered there is a amend order tab when you log into your account
Ok thank youExtra Case Fans
Good to know. Thanks!You don't need the extra fan at the back, because the two fans on the AIO work as exhaust fans, and the three fans in the front will make sure there is positive air pressure anyway, so it will be pushed out of the back of the case. That will probably be quieter than adding more fans to the mix, especially the budget ones.
Agreed, normally spec 1TB minimumThe gpu brand is normally zotac, pallit ,gigabyte 500gb storage for a gaming drive is on the low side is my concern
True but including a 1tb as well as the 500gb would go over my budget and I guess that storage is something that is easy to add to so it’s not the worst problem. Thanks anyway.Agreed, normally spec 1TB minimum
Ok thanks 👍The gpu brand is normally zotac, pallit ,gigabyte 500gb storage for a gaming drive is on the low side is my concern
Fair pointTrue but including a 1tb as well as the 500gb would go over my budget and I guess that storage is something that is easy to add to so it’s not the worst problem. Thanks anyway.
