Hello Everyone,
I have spent a while working on this spec and I think I have done a pretty good job with it but I would like someone with a bit more experience to advise me on any issues I may not have picked up on.
The main thing I am concerned about and am struggling to decide on is the motherboard. The main two options that seem best and also fit within the maximum amount I would spend are the Asus Tuf x570 Plus and the Asus rog strix B550-f gaming - I have heard of some issues relating to the 2.5gb intel ethernet that may have been fixed in newer versions of the boards (if you more about this can you update me on the situation) . I am unsure which I should choose so if anyone can help me with that it would be much appreciated.
I will mainly be using this build for gaming at 1080p with a 240hz monitor as I mostly play competitive games.
Thanks.
PS: my aim for the budget is for it to end up less than £1.9k.
8GB NVIDIA GEFORCE RTX 3070 Ti - HDMI, DP
Standard Build - Approximately 16 to 19 working days
Price: £1,825.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/rpJ7SbVcaz/
Thanks.
