[RESOLVED] Can't get 'Intel WiFi 6 AX200 Wireless Adapter' to work in Debian 11.
RayEcc
Hi RayEcc,
Could you please post the output of:
Bash:
lsmod | grep iwlwifi
It's strange,as according to https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi#supported_devices your card should be supported since Kernel 5.1, so your Kernel 5.16 is way ahead.
Some logs would be useful, in particular the output of:
Bash:
sudo dmesg | grep iwlwifi
Hi astiak.
Code:
Code:
iwlwifi               319488  1 iwlmvm
cfg80211             1052672  5 carl9170,iwlmvm,ath,iwlwifi,mac80211
The 2nd line 'sudo dmesg | grep iwlwifi' gave no output.
hogfish
Perhaps running
# lspci -k
(as root, or with sudo if necessary)
and confirming that iwlwifi is directly handling your hardware.
Running
# modinfo iwlwifi
shows that there are several parameters for iwlwifi which might perhaps be relevant.
RayEcc
Hi hogfish.
Output for lspci -k:
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
Kernel driver in use: pcieport
00:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
Subsystem: Gigabyte Technology Co., Ltd FCH SMBus Controller
Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
Subsystem: Gigabyte Technology Co., Ltd FCH LPC Bridge
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 3
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 7
01:00.0 Non-Volatile memory controller: Silicon Motion, Inc. SM2263EN/SM2263XT SSD Controller (rev 03)
Subsystem: Silicon Motion, Inc. SM2263EN/SM2263XT SSD Controller
Kernel driver in use: nvme
Kernel modules: nvme
02:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] Device 43bc (rev 02)
Subsystem: ASMedia Technology Inc. Device 1142
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
02:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] Device 43b8 (rev 02)
Subsystem: ASMedia Technology Inc. Device 1062
Kernel driver in use: ahci
Kernel modules: ahci
02:00.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43b3 (rev 02)
03:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
03:05.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
03:06.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
03:07.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
06:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
Subsystem: Intel Corporation Wi-Fi 6 AX200
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
07:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0c)
Subsystem: Gigabyte Technology Co., Ltd Onboard Ethernet
Kernel driver in use: r8169
Kernel modules: r8169
08:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X] (rev c7)
Subsystem: XFX Pine Group Inc. Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
Kernel driver in use: amdgpu
Kernel modules: amdgpu
08:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
Subsystem: XFX Pine Group Inc. Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
09:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
0a:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
0a:00.1 Encryption controller: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
Kernel driver in use: ccp
Kernel modules: ccp
0a:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
Subsystem: Gigabyte Technology Co., Ltd Matisse USB 3.0 Host Controller
0a:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
Subsystem: Gigabyte Technology Co., Ltd Starship/Matisse HD Audio Controller
RayEcc
The output for sudo modinfo iwlwifi seems to output info that perhaps sensitive? What lines are specifically needed here? Thanks.
RayEcc
My PC has multiple drives. I installed Fedora 36 on another drive. The AX200 WiFi card worked out-of-the-box.
I'll still use Debian 11 as my main OS but at least now, I know the AX200 WiFi works fine on Fedora and likely will work in Debian 12 without having to jump through hoops.
I've 2 WiFi dongles that work OOTB in Debian 11 so that area is covered.
