Rendering Desktop
steve.r
Damn that looks slick hehe. Thank you very much bud I will surely be purchasing them as well :)
BTW, is it possible to engrave a word on a case? I know it sounds crazy just that I want that extra touch lol
It is possible, some sites will offer those services but you need to arrange it since PCS do not offer that sort of customisation.
steve.r
Nice one bud.
I think I will be going for mantadog recommendation, but will be upgrading the RAM:- 32GB Kingston HYPERX BEAST Quad-DDR3 2400MHz
Here's what he recommended:-
COOLERMASTER CM Storm Trooper
Intel® Core™i7 Six Core Processor i7-3930K (3.2GHz) 12MB
ASUS® P9X79 LE: INTEL® SOCKET LG2011
16GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz, X.M.P (2 x 8GB KIT)
2GB NVIDIA GEFORCE GTX 770 - 2 DVI, HDMI, DP - 3D Vision Ready
240GB INTEL® 335 SERIES SSD, SATA 6 Gb/s (upto 500MB/sR | 450MB/sW)
CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£79)
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/intel-2011-extreme/pPMNGQtknU/
I will be able to add some extra money to the build. So where do you think I can make improvements? Better HD? More Graphics card?
If you are going with the i7-3930k it will be a waste not to overclock the cpu :), if you are planning to add 32gb RAM you need windows 7 professional. Is there any gaming involved? Considering how much you are spending I'd also suggest upgrading the warranty.
steve.r
I'm not a computer geek just have little knowledge bud, is it easy to overclock the cpu? At the moment there is no gaming involved but I do capture gameplays using Elgato Game Capture HD. But hoping to get into gaming perhaps after a year. But I want to have all the features and components ready when I get into gaming.
So you would recommend on the following upgrades:-
Windows 7 Professional
Thanks bud
Thanks bud
PCS offers pre-overclocked systems:
http://www.pcspecialist.co.uk/computers/intel-2011-overclocked/
steve.r
What happens when a system has been overclocked? It's running on maximum speed at all times bud?
Also can it be done manually because a friend of mine is quite good with these stuff.
It can be done by changing settings on the BIOS, the clock speed will increase to a maximum of 4.6ghz (stock is 3.2ghz). The difference in price is very small, I'd prefer PCS to do the overclock for me since they have plenty of experience and expertise with overclocking similar systems.
steve.r
Sounds great bud.
Do PCS built the PC or do they send the parts? Sorry but I haven't ordered from them before.
Sounds great bud.
Everything will be build and fully tested. The only thing you need to do is plug the power cable, monitor, peripherals.
steve.r
Great bud, just say I don't overclock the system with PCS can I do it manually at a later stage?
steve.r
Ok bud sounds great, I maybe able to purchase the parts separate from a mate who sells components, will it be ideal to purchase from him? Or do you recommend purchasing directly from PCS?
From experience when looking at purchasing from PCS the difference in price was not significant, actually almost the same. If I am spending more than £1000 I wouldn't build it myself or someone else unless you are going to get a decent warranty and replacement of parts if parts are faulty. Last week my cpu cooler started making a grinding noise, I called PCS technical support and next day I was sent a brand new cpu cooler. I have dealt with many retailers and the level of support and customer service from PCS is second to none.
steve.r
Hey keynes sorry for the late reply I haven't been well. Thats almost everything sorted bud. Appreciate your help and others so +1 rep point for those who have helped.
Just say in the future will I be able to add additional graphics?
