You can’t flash the BIOS without PCS approval otherwise you’ll void your warranty.Hi. Booted up my machine and noticed the pc specialist logo.
I assume a firmware reflash of the bios takes care of this?
Its my machine i do what i want with it?Flashing a BIOS only to remove the PCS splash screen is not sensible. It's there for a few seconds only, why do you care?
What about manufactory warranty? I already transplanted the new mobo and cpu and ram into my own case with my own storage and psu so i highly doubt its in warranty anywayYou can’t flash the BIOS without PCS approval otherwise you’ll void your warranty.
The manufacturer warranty you would have to check with the manufacturer.What about manufactory warranty? I already transplanted the new mobo and cpu and ram into my own case with my own storage and psu so i highly doubt its in warranty anyway
Of course you can, but risking a BIOS flash just to replace the PCS splash screen with a different one (that lasts just as long) defies common sense.Its my machine i do what i want with it?
But yes having moved a lot of stuff it sounds like your PCS warranty may be refused anyway (though it may be considered on a case-by-case basis) - this is taken from https://www.pcspecialist.co.uk/terms/
Never flashing your bios in a time of security issues on both amd and intel and both releasing new bios with more features also defies common sense.Of course you can, but risking a BIOS flash just to replace the PCS splash screen with a different one (that lasts just as long) defies common sense.
Well it's your call but if it ain't broke then don't fix it.Never flashing your bios in a time of security issues on both amd and intel and both releasing new bios with more features also defies common sense.
If the splashscreen gets removed on my next update cycle. Happy days and a added bonus
Well its 2 bios versions behind. Both which fix certain known issues and one that i already encountered (usb issues).. so ill have to updateWell it's your call but if it ain't broke then don't fix it.
It would seem your warranty is shot now in any case but its still worth talking to PCS. They can tell you whether these updates are relevant to your build.Well its 2 bios versions behind. Both which fix certain known issues and one that i already encountered (usb issues).. so ill have to update
B550f motherboard.It would seem your warranty is shot now in any case but its still worth talking to PCS. They can tell you whether these updates are relevant to your build.
this is a great point, why the hell would flashing bios void warranty? i been regularly updating my bios in old machine as soon as windows update notified me there is one available.Never flashing your bios in a time of security issues on both amd and intel and both releasing new bios with more features also defies common sense.
to add to my previous post, especialy if they wont even bother updating bios in a first place to newest version.Well its 2 bios versions behind. Both which fix certain known issues and one that i already encountered (usb issues).. so ill have to update
Reason 1. Because (even today) you can brick a PC/laptop if you flash the wrong image or in the wrong way.this is a great point, why the hell would flashing bios void warranty? i been regularly updating my bios in old machine as soon as windows update notified me there is one available.
I sure as hell wont have security risks on my new machine just to keep warranty with PCS, that is just stupid.
bios update is sometimes a part of windows update tho (granted i think it is optional update there) but the point is that inexperienced user might just update it because they see it in windows update, and bam warranty voidedReason 1. Because (even today) you can brick a PC/laptop if you flash the wrong image or in the wrong way.
Reason 2. Just because a board vendor supplies a new BIOS doesn't automatically mean you need it. The update might be to support (or fix support) for a device you don't have.
Reason 3. You implicitly accept the Terms & Conditions when you buy from PCS and they require you to seek their authorisation.
AFAIK you cannot flash the BIOS firmware via Windows Update. On an Intel build you can update the Intel Management Engine via Windows Update, which is an Intel firmware update, but that's not your BIOS.bios update is sometimes a part of windows update tho (granted i think it is optional update there) but the point is that inexperienced user might just update it because they see it in windows update, and bam warranty voided
i am pretty sure i have received bios updates via windows updateAFAIK you cannot flash the BIOS firmware via Windows Update. On an Intel build you can update the Intel Management Engine via Windows Update, which is an Intel firmware update, but that's not your BIOS.
Do you have an example of a Windows Update that flashes the BIOS? I've never ever seen one but would be interested to know if such a thing exists. I can't quite imagine how it would work though...
I'd be very surprised if you have. But I've been surprised before...i am pretty sure i have received bios updates via windows update
