A couple of years ago, I bought two identical computers.
Within a year, the first one had the CPU cooler fail. Unsurprisingly, as there is obviously a problem with these coolers, the second one appears to have also failed.
It is getting sent back to be assessed and repaired and, ideally, I'd like to have something OTHER than a like for like repair - I really don't want another one of these coolers because it just doesn't seem worth it.
I was hoping to get it replaced by just a normal heatsink/fan, but looking at the rest of the PCS site, it doesn't look like they tend to do them -- they're all liquid cooled.
So I'm looking for some recommendations - if I'm able to get them to put something else in, which should I ask for (working on the assumption that, as they have obviously still been using these PCS Frostflow things, that don't appear to be fit for purpose, so I can't rely on PCS giving me reliable advice).
Is there anything in particular I should be looking for? or avoiding?
Case | COOLERMASTER MASTERCASE H500 GAMING CASE![]() |
Overclocked CPU | Overclocked Intel® Core™ i7-10700K Eight Core (3.8GHz @ up to 3.8GHz) |
OC BIOS FIle | |
Motherboard | ASUS® TUF Z490-PLUS GAMING (LGA1200, USB 3.2, CrossFireX) - RGB Ready![]() |
Memory (RAM) | 16GB Corsair VENGEANCE DDR4 3000MHz (2 x 8GB) |
Graphics Card | 8GB NVIDIA GEFORCE RTX 2070 SUPER - HDMI, 3x DP GeForce - RTX VR Ready! |
1st Storage Drive | 2TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 256MB CACHE |
1st M.2 SSD Drive | 512GB Intel® H10 NVMe SSD + 32GB Intel® Optane™ (upto 2300MB/sR | 1300MB/sW) |
DVD/BLU-RAY Drive | NOT REQUIRED |
Power Supply | CORSAIR 650W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET |
Power Cable | 1 x 1 Metre UK Power Cable (Kettle Lead) |
Processor Cooling | PCS FrostFlow 120 Series RGB High Performance Liquid Cooler |
Thermal Paste | STANDARD THERMAL PASTE FOR SUFFICIENT COOLING |
LED Lighting | 50cm RGB LED Strip |
Sound Card | ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD) |
Wireless Network Card | WIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0 |
USB/Thunderbolt Options | MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS |
