A rather expensive but effective cure for Mondayitis
Shush!!!
Has now been dispatched, woohoo!!
Shush!!!
To be honest I wouldn't mind it getting delayed it is was for more testing (well to a certain extent)
Though this morning was an oddity, I am actually sat here grinning on a Monday morning
By testing I mean put it on the shelf to test how well it 'stands'
If that isn't already part of the Testing/QC process, then I demand it be added! I mean, its what the PC does 24/7, more than its actually on, so clearly a far more important test than whether or not some poxy card or fan works...they are only on SOME of the day
It's going to seem like a long day.Its here! Its here! Its here!
Unfortunately I can't really connect it up til lunchtime, since I'm using my current PC for work, but I have unboxed it, and taken out the foam packing
And after I've had my lunch I need to go back into work
I know, my boss is also a gamer and is probably going to be teasing me about it all afternoon and has told me if I ring in sick he will come round and drag me into workIt's going to seem like a long day.
I'm working from home, I'm remoting into my work PC, I am not pouring my drink over my PC at home that has served me well!!!!Step 1: "Accidentally" knock over drink onto work PC
Show a bit of commitment to the cause sir....
Well I got it all connected, apart from the sound (but I'll come to that later this evening), booted successfully into Win8, failed to find out how to shut down til I asked a friend, and then had to come back to workShow a bit of commitment to the cause sir....
Rakk is a lady
Since English is not my first language, could you elaborate?It'd be so easy to comment on this, and although it would be meant with no malice and purely for comic effect, I feel it may come across the interwebs differently
Do you get a switch to turn them off? how many are blue led?The blue led fan was nice and bright and blue
Its just the fan at the front that can be lit up, and yes, there is a little button by the usb ports on the top so you can turn it off (though I havent tested it yet).Do you get a switch to turn them off? how many are blue led?
The button is a little below the surface of the case,you may need to use the blunt end of a pencil or something like that to press it right down.Its just the fan at the front that can be lit up, and yes, there is a little button by the usb ports on the top so you can turn it off (though I havent tested it yet).
Edit: at some point I will try and get some pictures up
