Agree, the rad isn't in the ideal place either, the pump looks like it's at the highest part of the system and thats deffo not where you would want any air bubblesI would not be happy with that radiator placement
I didn't like it at first but the motherboard VRMs and the RAM height don't make it possible for a top mount i think. Also PSU shroud blocks hoses from being downward i believe.I would not be happy with that radiator placement
Nope, looks like no room for a top mount nor having the hoses be at the bottom.Was wondering if there was room for top mounting lol
Just done testing.Exactly, installed that way round the tubes need to be above the pump.
Yeah didn't like it at first, 3 front fans and then the AIO on top of them thought it was a bit weird, but after testing i realised it's perfectly fine and it's not like I'm going to be starting into my PC 24/7 so i don't mind. Had a few friends run the h100 in the same orientation and they've not had issues after years of hard usage, so I'm inclined to agreeIt should be fine, it certainly is going by your performance checks.
I'm never a fan of that particular layout but any issues would be apparent quite quickly and I think the QC on water coolers has came a LONG way to avoid airbubbles and the likes. If you get any issues with it simply raise the radiator and spin it 180![]()
