Motherboard is nothing to do with the GPU. It's the CPU that's the issue. CPUs with more cores need more voltage to remain stable at a certain clock speed. More voltage = more heat. If you don't have adequate VRM capacity, the speed of the CPU will drop. If you don't have adequate cooling capacity, the speed of the CPU will drop.
Nothing will break so I'm sure you will be more than happy. It's just a bit of a waste as the performance will be hampered by the choices made. Nothing too dangerous though.
