JediMonsoon
Hi, Here is my spec
ASUS® CROSSHAIR VIII HERO WIFI (DDR4, PCIe 4.0, CrossFireX/SLI) - RGB Ready!
10GB NVIDIA GEFORCE RTX 3080 - HDMI, DP
2nd M.2 SSD Drive
2TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2700MB/sW)
Corsair H150i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
Non Required
NONE
Standard Build - Approximately 9 to 12 working days
2nd M.2 SSD Drive
Non Required
NONE
Everything has been working fine. I upgraded to Windows 11 about 3 days ago and updated all the graphics drivers and chipset etc. Everything fine.
I turn on my machine today and there is a strange kind of pixelation to the computer image. It isn't as obvious on bright images but you can see it on a dark screen and dark parts of the screen. I used a 4K TV via HDMI as a monitor and the images are fine other than the PC. It shows on the PCS boot screen also so I'm guessing its not a Windows issues.
Here is a link to a couple of photos I tool while getting the computer to restart. Not the best but I think it gives you an idea.
If anyone can help I would be most greatful
2nd M.2 SSD Drive
Non Required
NONE
2nd M.2 SSD Drive
Non Required
NONE
