Good afternoon fine people.
These are my specs in case it might be needed
I managed to get a 3060ti at mrsp(must’ve stepped in dog poo for a week to get one). Only for my pc to die the day it arrived *cleans dog poo from shoe*
Now it is currently sat in the fine building at PCS, but my worry is the problem not being what I think it is and waiting longer than I’d hope to wait.
My pc would turn on but not post. No bios no windows no actually input to my monitor. Fans would work, rgb lighting would work but nothing else.
Now I’ve reset my cmos with the 2 pins as well as removing the battery for 20 mins.
Reseated the cpu, gpu and both ram sticks, using just one in each slot as well as putting the gpu into my second pci-e slot but to no avail.
Now what bothers me is when I turned it on with a missing part, no light or noise comes from the mobo to tell me that piece is missing.
So I’m just wondering with the current supply issue with everything apart from motherboards would anyone think the issue is actually the mobo and nothing else?
Processor (CPU) | AMD Ryzen 7 3700X Eight Core CPU (3.6GHz-4.4GHz/36MB CACHE/AM4) |
Motherboard | ASUS® TUF X570-PLUS GAMING (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - RGB Ready! |
Memory (RAM) | 32GB Corsair VENGEANCE DDR4 3200MHz (2 x 16GB) |
Graphics Card | 8GB NVIDIA GEFORCE RTX 2060 SUPER - HDMI, DP - VR Ready! |
1st Storage Drive | 256GB PCS 2.5" SSD, SATA 6 Gb (500MB/R, 400MB/W) |
2nd Storage Drive | 2TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 256MB CACHE |
Power Supply | CORSAIR 650W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET |
Power Cable | 1 x 1 Metre UK Power Cable (Kettle Lead) |
Processor Cooling | PCS FrostFlow 80 Series High Performance CPU Cooler (AMD) |
Thermal Paste | ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND |
Sound Card | ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD) |
Wireless Network Card | 10/100/1000 GIGABIT LAN PORT (Wi-Fi NOT INCLUDED) |
USB/Thunderbolt Options | MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS |
