It depends on your router,whether you choose the 150 or 300Mpbs PCI-E card,homeplugs could be a better option.One last question.
Which wireless card is best out of the ones available? The desktop will be upstairs and will need to be wireless to connect to the router downstairs.
Thanks.
I was told by a PCS guy that the standard AMD coolers are supplied and designed for the AMD FX processors ,but if a quieter processor is preferred,to go for the Triple copper heat pipe cooler.Just how much difference in noise there is,I really couldn't say.Thanks.
Will leave the wireless and go for the triple copper cooling instead.
Is there any difference between the standard cooler and the copper one?
Windows is asking me to activate it. I don't have a key however. It was not provided with the Windows 8 disc. What shall I do?
