chrisrs2292
So as mentioned before my order, this was my 3rd pc from PCS, but this is the first review i've written.
The spec for the pc is:
SILVERSTONE RAVEN RV03 - GAMING ENTHUSIAST TOWER CASE
Intel® Core™i7-2600 Quad Core (3.40GHz, 8MB Cache) + HD Graphics
ASUS® P8P67 (NEW REV 3.0): USB 3.0, SATA 6.0GB/s, CrossFireX™
3GB NVIDIA GEFORCE GTX 580 - 2 DVI, HDMI, DP - DX® 11, 3D Vision Ready
120GB INTEL® 510 SERIES SSD, SATA 6 Gb/s (upto 450MB/sR | 210MB/sW)
CORSAIR 650W TX SERIES (TX650) 80+ ULTRA QUIET PSU (£72)
My order was placed on the 2nd of June with the standard build and delivery, it arrived today which was the 12th working day.
First, thanks to these guys at PCS who built, tested and packed my PC, and thanks to everyone on the forums who helped with my spec
Built By - Sanjit Ghosh
Tested By - Zbear Ramzan
QC'd By - Craig Whiteley
Packed By - Anthony Cunliffe
My first 2 pc's from PCS both arrived with no issue, and I hoped the DHL guys would treat this one just as gently. The box arrived and didnt look as if they'd played football with it (woo) apart from one hole in the side of the box
Other than that though the pc looked alright, upon removing the pc from the box however i could here a small rattle, concerning at first but turned out it was just a part of the case which had probably been broken off in transit, should be easily replaced however, the bit that was broken off was a clip for the top cover of the case
After figuring out where the power lead was connected (bottom of the pc >.>) was easy to set up, and the packaging foam seems to have done the job of keeping all the components inside.
It's all setup now, important programs are installed and now i'm just waiting for steam to download a few games before i test it out properly. Windows gave me a rating of 7.7 (processor letting me down ;P)
Final thoughts, thanks to PCS for building me another great PC, cant really fault their service as they kept me updated throughout the build, my sub-order was put in no problem, arrived within the estimated time, worked out of the box, and i'm a happy bunny and cos i couldnt resists, one last pic of it
all the photos can be found http://www.flickr.com/photos/chrisrs2292/ in case you wanted to have another look
edit: quick update on the broken case, spoke to someone from tech support yesterday, he had a look at the pics on here and will be sending out a new top section of my case
