DarkPaladin
I'm not an expert with 4K gaming, so I probably can't give the best answer here.
When buying a monitor, you generally have to ask yourself a few questions:
1) What do I want the monitor to ideally achieve? E.g. highest refresh rate with minimal ghosting, best image quality, HDR gaming
2) Does my current hardware get the most out of the monitor? Such as being able to achieve a high framerate at 2K, or 4K
3) Does the monitor you have in mind have known QC issues? From my experience, Samsung make great monitors but their QC is very mixed for a lot of people.
4) Do you ideally want IPS, VA, or OLED? All 3 of these have pros/cons. For example, OLED has the best image quality but is prone to issues such as image burn in.
5) What size do you want the monitor to be? This is often underlooked, but is just as important as the others. Sitting up close to a 32" monitor will be difficult for some users, and pixels become more spread out under larger monitors.
6) What is the main purpose of the monitor? If your main function is text clarity, then office monitors with smart features may be best suited. If it is for the highest refresh rates with low ghosting and low input lag, then a gaming monitor is best.
For your specific setup, I don't know how good a 4070ti is for 4K gaming, but I imagine it should be able to achieve 60fps in most games. For single player gamers, this is not an issue at all. For multiplayer gamers, it may struggle to achieve high FPS due to the larger resolution.
Hope this helps!
Hope this helps!
