RobertCrentis146
ah, thank you very much! I appreciate the adviceWe've found that on a lot of boards with 4 x 3600MHz DIMMS, we've faced instability. It was only very recently that PCS actually allowed 4 x 3600 DIMMS at all, in fact I think they even took off 3600MHz all together at one stage because of the problems they were having getting it stable.
On the forum, we recently had a user with 4 x 3600MHz DIMMS with instability, but we lowered the DOCP (memory overclock profile) down to the next lowest setting which is 3533MHz, and that remained completely stable after about 36 hours of continuous testing.
I'd suggest speccing 2 x 16Gb DIMMS for now of 3600MHz, and then phoning PCS to ask if you can add another 2 DIMMS. I'm sure they'll accommodate you.
If you were to face instability, then we could drop the DOCP down a little until it reaches stability. Worst thing to happen is you'll have the clocks reduced a little until such a time as Asus / AMD release a BIOS update to address it.
But I'm very confident that IF you were to face issues, it would be stable at 3533MHz.
