I'll compare my setup with what you suggest, I might be able to squeeze out a bit more performance on my system. My best Cinebench R23 score is 31,040 - it will be interesting to see if my score goes up.If I'm not mistaken, Control Center settings will be saved in the BIOS. Am I correct, @SpyderTracks ?
PL1/PL2/PL4 values are insane, no surprise about thermal throttling
Try something like this to begin:
Enable Temp Limit - 85 (or anything below 90)
PL1 55, PL2 60-63, PL4 115 (even lower)
Deactivate - Enable Automatic GPU Overboost
Fan Switch Speed - much lower than that
Download some stress test software (e.g., Prime 95, AIDA64, Cinebench, OCCT, Furmark) and monitoring software (e.g., HWiNFO/HWMonitor) and run them for at least 10 minutes while reviewing CPU/GPU values.
3D Mark TimeSpy shows that I'm above average for my specs, (don't remember the score off the top of my head) so will be good if I can squeeze a bit more.
I run Micro$oft Flight Simulator and it's very resource hungry.
