Yes having read abut it some more myself I do believe you are correct, if it wasn't in a laptop it would probably be fine, but as it is then it can heat up other nearby components which is no good.
I've ordered the Samsung 850 EVO normal SSD to replace it, so I'll update on how the temps are with that instead
PCS should add a warning to the mSATA sections about how they can run hotter than normal SSD's. I wrongly assumed they were just like standard SSD's but without the extra casing/form factor. Having never had any temp issues on my current SSD's it just didn't occur to me tbh.
