Optimus Pro XI fan control ?
kyankov1
Hi
This is the laptop I purchased recently, but I can't seem to find any sort of fan speed control.
The laptop is very quiet however when using intensively it gets very hot and it doesn't turn any other fan speed.
Is there a special key combination that should activate different fan speeds (GPU, CPU) or it is a 3rd party software?
In addition, the Fn+1 key combination doesn't do anything.
Also, the picture attached should represent this "Turbo " button, which on each setting (off, dim led,bright led) doesn't seem to make any difference?
Is it working at all, or it requires some additional drivers?
Thank you for your time.
Optimus Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Intel® Core™ i7 Six Core Processor 10750H (2.6GHz, 5GHz Turbo)
32GB Corsair 2133MHz SODIMM DDR4 (2 x 16GB)
NVIDIA® GeForce® RTX 2060 - 6.0GB GDDR6 Video RAM - DirectX® 12.1
1TB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 470MB/W)
2nd M.2 SSD Drive
256GB PCS PCIe M.2 SSD (1900 MB/R, 1100 MB/W)
External DVD/BLU-RAY Drive
AC Adaptor
1 x 180W AC Adaptor
Optimus Series Integrated 46WH Lithium Ion Battery
Bluetooth & Wireless
GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6 AX201 (2.4 Gbps) + BT 5.0
OPTIMUS SERIES RGB BACKLIT UK KEYBOARD
NO RECOVERY MEDIA REQUIRED
Hi
2nd M.2 SSD Drive
AC Adaptor
1 x 180W AC Adaptor
How did you install windows?
How did you install your drivers?
Have you installed control center?
kyankov1
Hi
I got Windows 10 Pro with up to date windows updates.
Nvidia drivers are up to date and work well.
I haven't installed a control center. Is this the software I need?
Thanks.
kyankov1
Yes, but how did you install it, what method did you use? Sorry to sound obvious, but I need to verify if the laptop is properly configured.
And how did you install drivers?
Hi
I have it on a bootable memory stick from Microsoft Imagine(OnTheHub now) with a licensed key.
After installation I let it run its updates. Nothing extra. I am happy that it is quiet and there is no additional sound made when playing games or training neural networks, but I just want to make sure that it doesn't need anything extra to cool itself because it becomes very hot.
Drivers provided by Nvidia and some from Windows, they are fine, however, Windows does not install any additional for the fan or the turbo button.
Do I need something like control center or Fan Xpert and is this the optimal way to go?
Hi
Yes, you need control center installed, it's the management driver.
It's in your main PCS account in the tech support / downloads section.
zayter
Hi
Thank you, I found them, I shall install some more drivers now.
Regards
Are the fans boosting up now when they should be after installing control center?
This issue is the only thing holding me back from purchasing this laptop today.
