Amazing, you got really lucky, you must have got the order in pretty quick to snag a 5090 so early.6 Working days later and its already built, so much for expecting a month+ wait
5090 MSI Gaming Trio x Ryzen 7 9800X3D Combo
Que slot 11, so about as quick as I could possibly get the order in. If one of the parts didn't conflict id have got it quicker 😂Amazing, you got really lucky, you must have got the order in pretty quick to snag a 5090 so early.
Bravo, that’s great news
The question is, are you ready for it???Que slot 11, so about as quick as I could possibly get the order in. If one of the parts didn't conflict id have got it quicker 😂
I purposefully misspelt it for that very reason!Geforce...... *chuckle*
Correct me if i'm wrong the MSI gaming trio one has a yellow tip on the connector to make sure its correctly inserted right ? Will be double checking this for sure when it arrivesDon’t want to freak people out, but just to highlight for any 5090 owners, worth just checking the power input to the gpu and being doubly sure it’s all the way home and not under too much duress from a bend to soon
The connector is part of the PSU not the GPU. The GPU side connector from what I’m seeing is just a standard black.Correct me if i'm wrong the MSI gaming trio one has a yellow tip on the connector to make sure its correctly inserted right ? Will be double checking this for sure when it arrives
Again, that's the adapter you'd use if you didn't have an ATX 3 PSU. All ATX 3 PSU's come with native support for 12VHPWR or 12v2x6 connections, so you don't use an adapter, you'd use the cable that comes with the PSUThe MSI card does have a yellow tipped adaptor
Opted for the Hxi 1500W corsair one so plenty of juice with three EPS12V connectors, tell me I didn't fumble that decision 😂 Cant image it needed anymore than thatAgain, that's the adapter you'd use if you didn't have an ATX 3 PSU. All ATX 3 PSU's come with native support for 12VHPWR or 12v2x6 connections, so you don't use an adapter, you'd use the cable that comes with the PSU
If you have in fact ordered a 5090 build with an ATX2 PSU, I'd amend the PSU as quick as you can before it’s on build and you have to pay to male changes, just no way near suitable for the 5090
The 1200W ATX 3 Shift model would be far better. ATX 3 factors in 1.5 x the power for transient spikes which is quite a major amendment, they're also far more efficient. So a 1200W gives you 1800W headroomOpted for the Hxi 1500W corsair one so plenty of juice with three EPS12V connectors, tell me I didn't fumble that decision 😂 Cant image it needed anymore than that
Yeah, agreed, but I do rate Corsair as one of the better ones out there, they do tend to be on the consumer side.Although grain of salt being the manufacturers claims in any sense of it
