Nvidia graphics cards
Wozza63
Biblical Poster
right ok, so i just played the first mission in the train @1080p maximum settings (16xAF, 4xAA, Ultra Settings) and the results are all good
I use VSync so the majority of the time it was displaying 60fps, the lowest it went was to about 40fps but 90% of the time it was 50+
tom_gr7
Life Serving
That's interesting, as this review of the 560ti 448 core, compares the the 560 ti, 560ti 448 core and the 570 in bf3, and says 570 max fps of 37 @1920x1200.
What resolution are ya playing at?
Finn
You seem to be comparing different levels, I haven't played Bf3 but I would assume the level mentioned in the review - operation swordbreaker - is the slowest in the game. I'm also not sure if the 37 figure is an average or the lowest recorded.
baron75mk2
Banned
Its very good for A GTX 570 , id be pleased , but you really need to go out of the hummer to meet the guys & go do the mission where you have to drag team m8 out of the way & kill the rpg guys & some missions later in the game , but when it dropped to 40fps did you notice the difference at 40 fps vs the 60fps ? , if so you can in fact tell the difference between low & high fps - its just that you may be more used to seeing lower fps more than high fps ?
& with it jumping from 40 to 60 then to 50fps , this is why a lot of gamers try to get5 the highest fps they can (in benchmarks with no v-sync) so that when they v-synch it it will have a better chance of staying at 60fps at all times without the dips (eg , no vsynch - between 60 & 70fps , chances are when v-sync is enabled the fps will dip at points , but say with 100- 130 fps , not much chance of dips when v-sync is enabled , dont know what i get with no v-synch , havent tried , but i get 60fps at all times v-synch enabled.
Update just tried it with no v - sync , 4x AA, 16x AF - all other settings max ( on operation swordbreaker - not counting cutsceene as this is just video anyway , not in game)
Inside hummer = MAX 98fps , MIN 82fps.
Exiting Hummer (looking around every where) = MAX 88fps MIN 79fps
Main mission from start to finish = MAX 196 fps MIN 79 fps (big fps spikes in certain places when the action has died down a little)
Whole thing , complete mission MAX = 196fps MIN 79fps
& again with v-sync enabled 60fps solid at all times .
Hardware ;
CPU - i5 2500k (stock)
GPUs 2X GTX 580 SLI (3gb models)
Ram - 8gb 1600mhz (xmp)
PSU - corsair 1,200w 80+ gold modular
Driver version 296.10
Max GPU temp (no v-sync) = 79c ( v-sync enabled 68c)
Pretty pleased with this , didn realize i was capable of peaking at 196fps in this game with everything maxed out :yes:
tom_gr7
Life Serving
lol i tested too, was always between 90 - 120, sometimes dipped 85 for a second or so, or jumped to 130+
temps were low bout 65ish, cause I up the fan speed.
Wozza63
Biblical Poster
is the hummer the next mission? I thought you were talking about when they were driving through NY (or whatever city it was)
if it is ill try in a bit
baron75mk2
Banned
The hummer is directly after the train bit ( they are sitting in the back of it listening to johnny cash) , then they step out - the mission is operation swordbreaker ( i benched the whole mission from start to finish , not counting the cutsceene before that as its just video & not 3d graphics )
Wozza63
Biblical Poster
ok so i was getting a pretty constant 45-50 fps, i got 60 quite a bit and the lowest i got was 33/34 and that was only during the first battle for a few seconds
baron75mk2
Banned
its very good for A gtx 570 i would say - now just for giggles , turn everything down to low or medium & play same mission at 60fps at all times ( forget about what it looks like) & just see if you can notice visual & gameplay smoothness as opposed to the current set up ( although if using keyboard & mouse it could still be a bit rough in turning as soooo many pc games seem to be these days , must be due to console porting never used to be this way - use a 360 controller if you have it , lots smoother ( but not as accurate as a kb/mouse , clear that up before it starts - lol)
I prefer kb/mouse for precision & extra buttons - but if its making my game rough as hell when turning , then whats the point of high lvls of fps ? ( just my personal thing , wherever possible i use kb/mouse , but its becoming very hard to find a game that turns as smoothly on the mouse as on the pad - dead space 2 was the last one i can remember)
Maybe i just need to invest in a better mouse ? dont know really as i was going to buy a real expensive gaming mouse , but then read lots of forum posts with gamers with very good gaming mice still having the issue with most games , so when shoving the pad in & all issues gone , it tells me they are more desighned with pad in mind & then the mouse is emulated for the pc version , whereas back along it was the other way around & games were always smooth on the mouse.
Wozza63
Biblical Poster
i cant notice any difference between 30 and 60, only if there is a huge sudden drop from 60 to 30 but if it goes down slowly i wont notice it
baron75mk2
Banned
Yes it different for everyone , but your better off TBH , you dont need to keep upgrading & spending cash constantly to get 60fps. :yes:
baron75mk2
Banned
yes, well i built my PC to take another 570 too so I always have that if i do need to upgrade
Yes you could always sli in the future - but be carefull if you catch the 60 fps bug you cant cure it with any medicine , very addictive - lol :yes:
Wozza63
Biblical Poster
lol i think it would be more of a cold turkey kind of treatment :p
I get 60fps most of the time i think on bf3 and most other games i definitely get 60fps, and i sees no difference
baron75mk2
Banned
yes definately a cold turkey treatment & im avoiding it for as long as i can ( probably why i dont play my consoles much , unless its a 60fps game , not may of them on console though) :yes:
