Should of maybe added it will be on a gaming computer
Really? I thought it would be for word processing lol :death: Seriously as everyone said the GTX 680 is the best GPU out there atm
Not anymore, they apparently just announced a 690
Go with GTX 680 , a fair bit faster than a single GTX 580 - BUT , if you have the case , power supply , cooling & cash to do it , Get Two GTX 580s & SLI them , Lots better minimum & maximum fps than a single GTX 680 can deliver - but also a lot more heat generated & a higher power requirement to boot , but with two of them in SLI theres no game you wont be able to max out & achieve 60fps at all times ( exept a few cpu bound poorly optimized games out there ) - but as far as real high spec games like battlefield 3 & witcher 2 (two of the most high spec games i can think of at the moment) , youll stamp all over them , where a Single GTX 680 will be struggling to get an absolute 60fps at all times at max/ultra settings ( exept ubersampling on witcher 2 , just kills the game in terms of fps & does not really add anything to the visuals to justiy the FPS hit at all)
PS; would not worry about the 690 , it is another dual chip fiasco like the 590 was , the most overpriced , problematic & overheating card i ever had - stay with the 680 is my advice , if you want SLI go with the above set up :yes:
Possibly the only game that wont run at max settings & full 60fps at all times on a GTX 580 SLI setup would be crysis 2 with the DX11 & extra texture pack installed , but his just means the single GTX 680 will only be worse anyway , cant comment on the texture pack as i have not seen it , but as far as DX11 , hardly any difference (unless your going around the game actually looking for it) & just kills performance (maybe more noticable with the texture pack installed) , but for me the DX9 is very nice on its own & runs perfectly :yes:
Im pretty sure i single 680 would wipe any game and will give him the option to get a second later, I have a 570 (no OC) and I have yet to move a game below maximum settings, that includes bf3 on the largest maps, although this ubersampling may not work very well, but i will see
The eye wont notice the difference between 30 and 60fps, but running at 30 and getting a dip will be noticeable.
I have a 570 like wozza and notice no slow down at all on bf3on Max settings 64 maps
Given the popularity of fast paced games on console @ 60fps (eg wipeout and similar) its fairly clear that in general, most gamers can see the difference between 30 and 60 (or 25/50).
24fps is generally accepted as the minimum required for motion to appear continuous, but the popularity of 120hz TV's shows that even 60 is not an upper limit.
well i cant tell the difference
And i probably get at least 30fps at all times (although like anything it has its occasional moments where it lags quite a bit (even on the smallest maps) but any map i play runs fine and i always play 64p servers too (mainly 64p metro which has about 100 explosions going off every 5 seconds)
Is there actually a frame counter on bf3? If so I may try it and see what i could get
I could never tell the difference between bf and cod framerates on console as bf is locked to 30 and cod is locked to 60
