nova 1TB PCS PCIe M.2 SSD (2000 MB/R, 1100 MB/W) not working
dylgri
I recently got my nova 2 days ago and my 1TB PCS PCIe M.2 SSD (2000 MB/R, 1100 MB/W) is not working it was working yesterday when i started it the first time but when i was trying to put files in it decided to do this before i call PCS has anyone had this problem before
dylgri
Chassis & DisplayNova Series: 15.6" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Processor (CPU)AMD Ryzen 7 3700X Eight Core CPU (3.6GHz-4.4GHz/36MB CACHE/AM4)
Memory (RAM)32GB Corsair 2666MHz SODIMM DDR4 (2 x 16GB)
Graphics CardNVIDIA® GeForce® RTX 2070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
1st Storage Drive1TB SEAGATE BARRACUDA 120 2.5" SSD, (up to 560MB/sR | 540MB/sW)
Change to: NOT REQUIRED
2nd M.2 SSD DriveNONE
Change to: 1TB PCS PCIe M.2 SSD (2000 MB/R, 1100 MB/W)
Memory Card ReaderIntegrated Micro-SD Memory Card Reader
AC Adaptor1 x 230W AC Adaptor
BatteryNova Series Detachable 4 Cell Lithium Ion Battery
Sound Card2 Channel High Def. Audio + SoundBlaster™ Cinema
Bluetooth & WirelessGIGABIT LAN & KILLER™ Wi-Fi 6 AX1650 M.2 GAMING + BLUETOOTH 5.0
USB/Thunderbolt Options1 x USB 3.2 PORT (Type C) + 2 x USB 3.2 PORTS + 1 x USB 2.0 PORT
Keyboard Language15" NOVA SERIES UK KEYBOARD
BrowserGoogle Chrome™
Notebook MouseCoolerMaster Devastator MM110 Gaming Mouse
Change to: TIMED DELIVERY TO UK MAINLAND - MON-FRI (BEFORE 10.30AM)
Build TimeStandard Build - Approximately 11 to 13 working days
this is also my spec
Could you right click on the start button, click "Disk Management" and post a screen shot of that?
dylgri
Hi Scot when i started it up this morning the drive was there but when i try to get into gta v files it says its inaccessible and when i restart my laptop the drive has gone again
In those screenshots the drive is there. When 'it says it's inaccessible' can you post a screenshot of that?
Can you also open a command prompt or PowerShell session and enter the command chkdsk d: /f /x (note that you'll have to reboot afterwards because chkdsk disconnects all open handles to the drive). That will check the filesystem on the drive, does that report any errors?
dylgri
when i try and enter the drive it just freezes sometimes and how do you open the command prompt where can i find that
just click on the start button and type cmd
If you open the drive within windows file explorer and go into the D drive, can you see the "Steam Games" folder?
ok it came up with something different this time
The drive is not formatted properly. Go into Disk Management again, right click on the graphical image of the drive and select Delete Volume. Then right click on the same graphical image and select New Simple Volume. Keep pressing Next to accept the defaults, when it comes to the drive letter change that to D (or whatever you want) click Next to accept the format defaults and finally Finish.
See how the drive is then.
dylgri
ok so i tried the new command and i says this and also i tried to do what you said and it came up with this and after i restarted my laptop again the drive is gone
You need to reboot and initialise the d drive as @ubuysa says
dylgri
ok i tried to delete the partition again on disk management and it comes up with this as i tried it again as the first time didnt work
