No display. PC beeping.
Zel
Have a problem where the screen of my pc went all pixelated. (See here for images)
I turned the pc off and on again, only for there to be no display and one long beep and three short.
I tried reseating the RAM which resulted in one short beep but still no display.
Moved the screen cable from the GPU to display port which got me one long beep and two short, still no display.
AMD Ryzen 7 7700X Eight Core CPU (4.5GHz-5.4GHz/40MB CACHE/AM5)
32GB Corsair VENGEANCE DDR5 5600MHz (2 x 16GB)
16GB AMD RADEON™ RX 6950 XT - HDMI, DP - DX® 12
PCS FrostFlow 150 Series High Performance CPU Cooler
ONBOARD 2.5Gbe LAN PORT
What happened in this thread as it seems to be a similar issue although this may be RAM related given the different BIOS code of one long 2 short after you'd changed port.
Zel
So am I looking at another RMA? Because the pixellated screen was different to last time. Then it appeared as large squares on the screen compared to what was showing now. Would it be the RAM or the GPU again?
No, we haven't done any troubleshooting yet, just wondering what happened as you never let us know?
I'm trying to identify if there is anything unusual in the way you're using the machine, or where it's situated perhaps that may be resulting in speeding up degredation of components.
Zel
Last time I got the GPU replaced with a new one which fixed the problem and I haven't had any issues with the pc until now.
So it was only the GPU, you didn't send the whole system back for investigation, just had a replacement GPU shipped?
Zel
And that's definitely all that was on the report? Just clarifying before we continue, often they will do multiple changes
Yes. Report below
Zel
That's perfect thanks, just wanted to clarify exactly what they'd done.
Are you comfortable removing the GPU? If so we can try that as a first port of call.
If it still fails to display on iGPU output, then we can move to testing the RAM with the GPU still removed.
I'll give it a try. Never done this before so, I don't want to make it worse.
Just need to unscrew the screw holding it to the rear case bracket, and remove the power connectors, then release the PCIe catch before removing the card.
Obviously be sure the PSU power switch is turned off before you do this
