New pc opinion of experts
StaPum
The 1st M.2 SSD is bascially for Windows, your programs and apps (stuff like the Steam launcher etc) and then the 2nd drive is where you install your games.
As to the PSU: The reason for that particular one is because it is one of the newer Shift models..they are more efficient and have better protection against GPU power spikes (although AMD cards are less prone to this than NVIDIA cards). If PCS supplied a lower wattage one, then it would have been recommended. It's fine to be over on the PSU, it won't draw more power or anything....the 10-20% is the minimum you should aim for...more than that is still fine
Thank you very much. One more question though, why is there no anti virus software in this build and why the firefox is the browser? Is there a particular reason for this?
Firefox is just one of the default options, feel free to change as you see fit.
The Norton 'trial' is pointless, as we recommend removing it immediately, as the built-in Microsoft Security is better...and won't screw up your computer or install a crypto-miner.
