New PC gpu and cpu underperforming
Kickim
Hello everyone
I just received my new PC 2 days ago and unfortunately it has problems regarding its performances. Noticed some poor fps in 1440p in a few games such as CODCW and Cyberpunk. After a few benchmarks in 3dmark(Time spy) I got the following results: 11281 for the gpu and 11979 for the cpu on the first benchmark (11380 overall) and the second one is a bit lower then the previous one with the gpu at 10284 points and cpu at 11831 points (10489 points overall). This results were made after reinstalling the drivers for my gpu. I had even worse points on it (around 8000 points) but following the instruction of someone from the support team I uninstalled the drivers of my gpu using a DDU from guru3D site and reintalled them afterwards. After reintalling this drivers I benchmark it again in 3dmark and recveived the points which I previously mentioned. I am not an expert and was thinking to RMA the pc but before that I was curios if you have any ideas of this problem. Any help is appreciated.
This are the links of the benchmarks in Time Spy:
I use a 1440p at the moment(LG 27GLB850-B)
I need to mention that all of my drivers are up to date.
CaseCOOLERMASTER MASTERBOX MB530P RGB GAMING CASE
Change to: CORSAIR CRYSTAL SERIES 680X RGB GAMING CASE
Change to: AMD Ryzen 9 5950X 16 Core CPU (3.4GHz-4.9GHz/72MB CACHE/AM4)
MotherboardASUS® TUF X570-PLUS GAMING (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - ARGB Ready!
Change to: ASUS® CROSSHAIR VIII HERO (DDR4, PCIe 4.0, CrossFireX/SLI) - RGB Ready!
Memory (RAM)32GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (4 x 8GB)
Change to: 4GB Corsair VENGEANCE DDR4 2400MHz (1 x 4GB)
Graphics Card10GB NVIDIA GEFORCE RTX 3080 - HDMI, DP
Change to: 24GB NVIDIA GEFORCE RTX 3090 - HDMI, DP
1st Storage DriveNOT REQUIRED
1st M.2 SSD Drive500GB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 6900MB/R, 5000MB/W)
Change to: 1TB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 7000MB/R, 5000MB/W)
2nd M.2 SSD Drive1TB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 7000MB/R, 5000MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 850W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET
Change to: ASUS ROG STRIX 1000W MODULAR 80 PLUS® GOLD
Processor CoolingCorsair H100x Hydro Cooler w/ PCS Ultra Quiet Fans
Change to: Corsair H115i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
Change to: STANDARD THERMAL PASTE FOR SUFFICIENT COOLING
LED LightingNONE
Change to: 2x 50cm ARGB LED Strip
Extra Case Fans1x 120mm Thermaltake TOUGHFAN 12 Case Fan
Wireless Network CardNONE
Change to: WIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
USB/Thunderbolt Options2 PORT (2 x TYPE A) USB 3.0 PCI-E CARD + STANDARD USB PORTS
Change to: 2 PORT (1 x TYPE A, 1 x TYPE C) USB 3.1 PCI-E CARD + STANDARD USB PORTS
Change to: 3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour)
What's the story behind the RAM as I'm sure you aren't actually running only 4GB of 2400MHz on that system
Kickim
First thing to do is check thermals with Ryzen Master:
Can you also install iCue and make sure the pump is working?
I checked the temperature. Usually the cpu temperature in idle is between 40C and 46C while in full load is 77C. The pump is working fine but usually the Icue is showing me a temperature of 38C idle and 65 in full load. I don't know if that's alright honestly.
The gpu temperatures are usually low 49-50C and 67C full load
Kickim
I already had 32GB of 3600mhz ram from corsair and it would have been a waste of money to get another pair similar to these in my opinion.
I might be wrong though.
ColEyt
Given that you installed your own ram, is that running at default speeds, or is it actually running at 3600mhz ?
ColEyt
Just looked at your time spy results in more detail.
The clock frequency for your card is 1950mhz and your results show your average clock frequency for the test were 888mhz.
just for comparison when I ran the test for my 6700xt , clock frequency was reported as 2478mhz and average clock frequency was 2388mhz.
so to me that would suggest either an issue with the temp of your gpu, so it's performance is being throttled under load, a setting is disabled that shouldn't be within the gpu drivers, thus restricting performance, or else the card itself is faulty.
perhaps one of our posters with more experience regarding graphics cards will be able to offer more detailed constructive advice from the findings above
Think you hit the jackpot there what is your card temperatures on idle ?
ColEyt
Just seen that OP posted about temperatures earlier.
50c seems to be a frequent reference for idling on that card after doing an internet search, although have also read a lot of posts on other forums saying that they get between 25 -35c on idle.
However no matter what idle temp has been posted, the difference when under full load seems to be an increase of 30c +. Thus an increase of only 18c degrees from idle to full load seems strange.
I'm wondering if its a fan profile issue within the driver software, with the fans set to low, no matter what the load, thus the card is throttled.
If the OP sets his gpu fans to maximum using MSI afterburner, as well as setting all his case fans to 100% performance and runs the benchmark test again, just to see if there is any difference. Obviously it will be noisy during the test but may help point us in a direction or at least discount one potential issue
Again I'm just throwing ideas out with no real experience, just in the hope it may jog someone else's memory for a more in detail explanation or solution
Kickim
I need to correct myself. Instead of 49 I wanted to say 40. So usually it is between 40-50 degrees on idle. The temperature varies oddly. During a game or a benchmark thr gpu fans are running at 100% and keeps the temperature at 65-67 degrees. I haven't seen it going up over 67°C yet. I am using Firestorm app from zotac and from my understanding the gpu fans were supposed to be at 100% if the temperature goes over 85°C.
I once again checked the bios and noticed that the version I am using is 2311 which is an older one from October last year. If I am messing around with the bios update will I loose my warranty? I think I missed some information from terms. Also I know that if I would make a bios update I would probably get a slightly better improvement on my cpu but not so sure about the gpu.
Yes, don’t update BIOS without speaking with PCS as that will void it.
But it seems like a GPU issue rather than CPU so that’s unlikely to be the cause.
Have you changed any settings in firestorm?
Kickim
I haven't touch the settings yet. I am a bit scarred that I might be messsing something up in there having little to none knowledge. I tried to inform myself online but there are few threads regarding this issue. The only thing I checked in the app was the fans curves
Just to confirm, where did you get the GPU drivers from when you reinstalled?
What resolution and refresh rate monitor are you using?
Kickim
Guided by the support team I reinstalled them for Nvidia Geforce Experience. First time I installed all of my drivers I did it manually from their official site.
My refresh rate is 144hz in 1440p. I was planning on geting the new 27gp950 4k monitor from lg but because of what is going on with my pc I have to postpone it
I would uninstall gpu drivers again with ddu, but then don’t install them through GeForce experience, actually manually download the installer from nvidia, and when installing, do a custom install and leave out the audio drivers.
Kickim
So I did as you said. Firstly I booted my pc in safe mode so I could uninstall the drivers using DDU. After that I restarted it again and installed the nvidia drivers manually from their site and unchecked the audio drivers. Unfortunately there were no changes in performance
