avenge_420
Hi here, I'm new to the forums and I'm looking for some tips and input for this build i created (not yet ordered). The build is mainly for gaming , and I'm looking to not spend more than £2500 and would be more than happy to decrease the price further from what i selected.I don't think i will be performing any overclocking as I'm inexperienced and if i do it would probably just be small scale overclocking .The monitors which it will be used on is a 165 Hz 1440p screen and also 4k 60 Hz for extremely visual games.The choice of the surplus ram is for Microsoft flight sim and any other future games that might take up that much memory.
The key areas where I'm not sure is initially the motherboard selected , does it come with inbuilt Bluetooth and WiFi ( i selected a WiFi card as i wasn't sure),also does it lack any features which are key and might be present in other motherboards.
Secondly the overall choice of the CPU cooler , extra fan and case set up will it provide optimal cooling for the system.
Thirdly i also wanted to ask regarding i selected a semi modular psu since the modular was not in stock,all i know its something to do with inbuilt or not cables.
Finally I wondered does setting certain partitions (C & D) on the O.S drive effect performance or could i even leave the nvme drive just being as one and install games along with the system.
Thanks for any help and input given would appreciate it a lot .
System chosen :
Intel® Core™ i9 Ten-Core Processor i9-10900K (3.7GHz) 20MB Cache
ASUS® ROG STRIX Z490-F GAMING (LGA1200, USB 3.2, CrossFireX/SLI) - ARGB Ready
10GB NVIDIA GEFORCE RTX 3080 - HDMI, DP
1TB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 470MB/W)
LED Lighting
50cm White LED Strip
Price: £2,499.00 including VAT and Delivery
https://www.pcspecialist.co.uk/saved-configurations/intel-z490-pc/qTHpjsbE0J/
Thanks for taking time to read this : )
System chosen :
LED Lighting
