NEW MONITOR - mains or adaptors?
PC49laptop
Already have 1 LG monitor waiting for Amazon to pick up now its 2.
500+ish but so far most monitors seem 2-3 years old the LG choice was OK but current situation seems no new tech. Was looking for NOT curved, might change mind as seems limits choice.
They do all seem to be curved these days but I'll have a hunt for something not.
This ones a goodie, with HDR10:
This ones just silly good for the money, HDR10 plus 240Hz which you can grow into, it's on pre order atm:
This one is flat, but I think the other two above are generally better quality (this one doesn't specify the HDR type which usually means it's pretty poor):
PC49laptop
Thanks for reply and looking into.
Decided to keep a working LG monitor for now.
With this long story of Amazon monitor, 1st no UK plug, sent another Monitor instead of a uk plug, so then have 2 LG monitors.
LG happy to send a free UK plug but took a few weeks. Then waiting for Amazon to pick up first monitor using 2nd one, but told by Amazon no one able to handle 'LARGE' items so waiting to hear when they can pick up. Funny that they can send 2 screens but not pick em up.
Then this week the LG monitor died, we originally did not want to use the 'spare 2nd monitor' as it looked to have a lot of duff pixels when we first chose which one to keep. But on further checking seems OK, so will keep going with the spare LG monitor. Will work on telling Amazon that one they get back is broke now.
So thanks for looking into some monitors, will hope the 2nd LG keeps going, as the spec is pretty good just not 4k.
The LG monitor - UltraGear 32GK850F 31.5-inch - 16:9 QHD 2560x1440 144Hz, AMD Radeon FreeSync 2, VESA DisplayHDR, 1-5ms,
with latest HDMI & DP inputs. Fully height adjustable, tilt & swivel.
Regards Rob
