New machine
raymond a
Many thanks Tony. missed that memory option. so seems to be the HX1500i and the 2x 32 Gb. Will have to call PCS to enquire about the 2nd GTX 4090 to be installed in this build. Would it be simple enough for me to install myself bearing in mind I am not well clued up on the workings of PC's [ only know my way around the software I use ] If it would be simple and straight forward I would add it later on . I would also have the case size to consider might have to go to full tower.
Yes, quite simple to install another GPU, and that motherboard has 2 PCIe 5.0x16 slots to support dual-GPUs.
The hardest part about fitting a GPU is connecting & routing the cables from the PSU - but at least there's less of them with a PCIe3.1 12VHPWR PSU as you don't need 4-into-2-into-1 for each GPU, just the 2-into-1 cable 12VHPWR cable per GPU.
