New Gaming PC Advice
Dannilad
Hi all,
In light of all the intel news that has come out today, I've (hopefully) cancelled an order with pcspecialist and am looking to have some advice on what I should look to now.
I will attempt to post what I had originally intended to order in the form of a screenshot I had proudly been sending to some friends, but again, due to recent news I am after some advice on how to proceed.
The budget I have is around £1500-1600. The order I previously had ran around 1550.
Basically, I want the same gpu etc, but will need an equally performing amd cpu.
Please can anyone advise?
I'm mostly an fps gamer. I play destiny 2 religiously and is my bread and butter in terms of what I really want to run perfectly, but I am interested in other titles such as cyberpunk, forza and minecraft.
If you need to know anything else before making a suggestion please ask and I'll reply as fast as I can.
--EDIT--
Info from build:
PCS SPECTRUM G ARGB MID TOWER CASE (PWM)
Promotional Item
Intel® Core™ i5 14-Core Processor i5-14600K (Up to 5.3GHz) 24MB Cache
ASUS® PRIME B760-PLUS D4 (LGA1700, DDR4, PCIe 5.0)
12GB ASUS TUF GEFORCE RTX 4070 OC EDITION - HDMI, DP
Graphics Card Support Bracket
1TB PCS PCIe M.2 SSD (2200 MB/R, 1500 MB/W)
CORSAIR 750W CX SERIES™ CX-750 POWER SUPPLY
DeepCool AK620 ZERO DARK High-Performance Dual Tower CPU Cooler
ONBOARD LAN PORT
NO RECOVERY MEDIA REQUIRED
Firefox™
Corsair Bundle - K55 RGB PRO Keyboard & M55 PRO Mouse
Welcome Book
PCSpecialist Welcome Book
Logo Branding
PCSpecialist Logo
Packaging
PCS Trade Pack - New 2023
Link for the build:
Monitor - Gigabyte M28U
Uses - As above. Gaming, like Destiny 2, Cyberpunk, Minecraft. Some VR gaming.
Budget - £1600
Danny
Hi all,
Danny
We need all the other info please?
Dannilad
Sorry, I attached the image to the post but maybe it hasn't worked.
Previous order was
Processor (CPU) - intel Core i5 14-Core Processor i5-14600K (Up to 5.3GHz) 24MB Cache
Motherboard - ASUSR PRIME B760-PLUS D4 (LGA1700, DDR4, PCIe 5.0)
Memory (RAM) - 32GB Corsair VENGEANCE DDR4 3200MHz (2 x 16GB)
Graphics Card - 12GB ASUS TUF GEFORCE RTX 4070 OC EDITION - HDMI, DP
1st M.2 SSD Drive - 1TB PCS PCIe M.2 SSD (2200 MB/R, 1500 MB/W)
1st Storage Drive - 2TB SEAGATE BARRACUDA SATA-lI 3.5"
Power Supply - CORSAIR 750W CX SERIES* CX-750
Previous order was
Did you read the newcomers section? We need all the info asked for from that please.
Please check my first post, I think I've edited it with everything that's needed?
There's no way you'll be able to get something to power 4k 144Hz at £1600, you'd be looking over 2k for something suitable.
What you've configured above isn't suitable as it is, you'd have to spend far more to get it road worthy, all the money is in the GPU without the rest of the platform to support it.
We need to manage your expectations here and point out the shortcomings of the system that you specced. Low-balling most of the spec in order to select a performance GPU is not the way any of us would recommend you spend your money. The first part of the PC you will replace is the GPU and the only way this makes sense is if the rest of the PC supports modern upgrades. The Intel selection won't be a good choice for this, the DDR4 selection won't be a good choice for this. You have massively underspent on the power unit for the system, 750w basic PSU isn't going to cut it, you need a modern 750w PSU or an older gen 1000w PSU to have any sort of headroom.
4k gaming isn't going to be good on a 4070. You would want a 4070Ti Super as a minimum nowadays. The next generation cards will be out from Nvidia before the end of the year. You will be able to play at 4k with such a card but you're going to need to dial down the settings and you aren't going to be hitting high FPS targets over 120hz (which is what we would like to have).
With those limitations in mind and with a strict budget of £1600, this is the best I can manage. I would strongly advise going over the budget a little and opting for the 4070 Super, it's a good bit more performance for around £50. Actual entry 4k would involve a 4070 Ti Super which would add over £250.
AMD Ryzen 7 7700 Eight Core CPU (3.8GHz-5.3GHz/40MB CACHE/AM5)
12GB NVIDIA GEFORCE RTX 4070 - HDMI, DP, LHR
1TB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 4125MB/sR, 2950MB/sW)
CORSAIR H100x RGB ELITE HIGH PERFORMANCE CPU COOLER
ONBOARD 2.5Gbe LAN PORT
Price: £1,595.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/effX7!QnzB/
Unfortunately you have under-estimated the costs of a true 4k gaming rig. A high end offering would be closer to £3k. The main components are so expensive nowadays. If I was spending on a 4k system nowadays, even trying to be frugal, the below is what I would want. Note that the next generation chips are out from AMD in a couple of weeks. This may offer more performance for the same money or even bring the current prices down. If you can hold off until then it may be worthwhile.
You can see this is where you hit the £2k+ mentioned previously. As stated, it's still low-balling for ideal as the 4080 Super would be the ideal 4k card. I would also want the 1200w Shift in the system also, but 1000w can just about cover the spikes of the below.
CORSAIR 4000D RGB AIRFLOW TEMPERED GLASS GAMING CASE
16GB NVIDIA GEFORCE RTX 4070 Ti SUPER - HDMI, DP, LHR
CORSAIR iCUE H115i ELITE CAPELLIX XT RGB High Performance CPU Cooler
Price: £2,099.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/uCB9rA5vM9/
