Ok I havent done this will do now. Should I install drivers from Nvidia or from Zotac or it doesn't matter?This is a minidump (because it's a crash not a BSOD) and they don't contain all the kernel data structures, however it's good enough for this error.
There is a clear driver error in the active thread...
Code:fffff580`2d9f7148 fffff802`1ca3ad8b Unable to load image \SystemRoot\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_3621da861144492b\nvlddmkm.sys, Win32 error 0n2 nvlddmkm+0xcad8b
The nvlddmkm.sys driver is the Nvidia graphics driver. The module that failed was dxgmms2.sys, a DirectX driver, but it seems that the Nvidia graphics driver is the fault here (in any case, dxgmms2.sys is a Microsoft driver and this far less likely to have a problem).
If you haven't done so already I would use DDU to uninstall the existing driver (it will reboot) and then download and install the latest Nvidia driver for your OS and card. Note: Don't install the Nvidia Audio driver that comes with the Nvidia graphics driver, we've had several issues of conflicts with the Realtek audio driver and that one.
