Need help with mousepad
Hey there,
Got the laptop in October, havent used it much but the few times that I have used it, I have had some problems with the mouse and I am not sure how to fix it.
So if I am scrolling down a page, on the mousepad I would click on the side bar with 1 hand and the other i would slide up or down on the mousepad to, well, go up or down the page.
After a short time, that stops and if I try to click then slide, it wont let me but if I double tap and keep the finger on, then I can move up and down but again that stops working and it acts like the mouse button is stuck on. If I move the mouse over somewhere to click, it wont click, I dont know if I am explaining it well to be honest but it is getting hard to do anything when I cant use the mouse.
Its probably some setting I need to switch off maybe, I'm not sure.
There's an image on the mousepad of a lightbulb with an arrow pointing to a design of a mousepad that says on next to it and below it the same lightbulb but it has the lines around the head to signify it is on with an arrow pointing to a mousepad design and the word off next to it
Citrus_9
Expert
Hey there,
Is this a PCS laptop? Please show us the specs from your orders page. Some mouse pads have a little slider thing on the right and it works different, but not sure how as I'm currently stuck with my 9-10 years old laptop and there was no such a thing at a time. So maybe you could attach a photo of the mouse pad too? Gave you tried to adjust sensitivity settings?
Sorry, I forgot to add it while I was creating the post, it is a PCS laptop, I have checked the sensitivity, seems fine, here are the specs
Vyper Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Intel® Core™ i7 Eight Core Processor 10875H (2.3GHz, 5.1GHz Turbo)
32GB Corsair 2666MHz SODIMM DDR4 (1 x 32GB)
NVIDIA® GeForce® RTX 2070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
1TB INTEL® 665p M.2 NVMe PCIe SSD (up to 2000MB/sR | 1925MB/sW)
AC Adaptor
1 x 230W AC Adaptor
Vyper Series Integrated 91WH Lithium Ion Battery
GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6 AX201 (2.4 Gbps) + BT 5.0
1 x THUNDERBOLT 3 PORT + 3 x USB 3.1 PORTS
VYPER 17 SERIES RGB BACKLIT UK KEYBOARD
Carry Case
Tech Air 17.3" Classic Backpack
Laptop Cooling Stands
CoolerMaster NotePal L2 Laptop Cooler, up to 17.3 inch
INTEGRATED 1MP HD WEBCAM
Welcome Book
