Need help buying pc
KSJ WHU
I bought this pc in 2015, im guessing nothing is useful from this or is anything worth using or selling from it ?
Deleted member 17413
Is it running windows 10?
Storage drives, some may well be worth swapping into a new build, What are the fans like? Or does it come with a controller?
Im sure there would be some stuff worth harvesting.
KSJ WHU
Windows 7 i think i havent used it in so long. It has a GA-78LMT-Usb3 motherboard.
AMD PILEDRIVER FX-6350 Gaming PC (AMD FX-6350 Six Core 4.20GHz CPU, NVIDIA GTX960 2GB HDMI Graphics Card, 1TB Hard Drive, 8GB DDR3 Memory, HDMI 10 [ASIN: B00MRBFE8I
Thats all i know
Ash_
Master Poster
The windows licence may be salvageable. The rest is not going to fetch much, you could always try though.
They were still upgrading Win 7 to Win 10 for free.... and it can save you £100 quid on the new build if you transfer it to teh new one and install it yourself.
If you power it up, log onto microsoft and upgrade (or try to). Search the site for media creation tool, and it will have th eoption of "upgrade this PC" on the site. Win 10 is then free, if they are still doing it, and will be associated to your microsoft account (or if not, you can do this yourself very easily...)
Then you'll have a copy of Win 10 that you can swap over, when the new machine turns up, log onto microsoft to remove the old pc from the account (Win 10 licence stays as its now a digital one associated with your microsoft account) and you can load it onto the new machine and activate using your microsoft account as your login when you set the PC up (you can switch back to a local profile after easy enough if you just want to use it to activate only)
1TB hard drive could be useful to keep (HDD or SSD?) just as extra storage, not much else would be of use/value really.
KSJ WHU
I want the pc to have lots of lights so it looks aesthetically pleasing how do i go about that do the parts have lights or do you have to buy lights for it ?
JUNI0R
If you go for one of the cases from PCS, a lot of them have RGB fans included. The Lian Li is a good budget option, the Cooler Master TD500 Mesh is a good mid tier option and the Corsair 5000X is a good top end option that all include RGB fans. A number of the CPU AIO’s also have RGB fans. Then you can add an RGB strip for about £10 than can be controlled using motherboard software.
Ash_
Master Poster
5000X with a H115i elite capellix should be more than enough RGB for anyone, if not, add the aRGB strip and with a 5000X - you could realistically add another 5 fans, if you want to burn your retinas on RGB 😅
Ash_
Master Poster
Just made the changes to @SpyderTracks build. This is very OTT RGB though, we can scale back on the extra 5 fans etc
LED Lighting
2x 50cm ARGB LED Strip
5x Corsair LL120 RGB LED Fan + Controller Kit
Price: £2,271.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/j9Fv87wK0e/
JUNI0R
The more unicorn puke the better!!
KSJ WHU
Whats the difference on graphic card for example the build i need requires the 8gb nvidia geforce 3070. So why are some called EVGA and another asus, are they the same thing but different brand?
Ash_
Master Poster
They will use the same base 3070 tech, then change the cooling solutions etc, add rgb. EVGA are generally fantastic cards. The performance difference like fps, between the best and worst cards, will be very limited. However, Asus will make the ROG Strix clock higher, run cooler and therefore boost more, but the difference will only be small - so a rog strix 3060ti will not even touch a bottom 3070 card
