My first pc build
ColonelMicrowave
I've installed my own copy of windows on my computer now, however in file explorer it only shows one of my drives (the one that I selected during the custom install menu) and the other one is not showing up.
Go into disc management, and you'll see both drives there, the second one probably needs to be initialised, or creating a simple volume
ColonelMicrowave
What should I do if I don’t have any option in settings to turn on Bluetooth (the button to turn it on is missing) same with WiFi. In Device Manager, Bluetooth is also missing.
Can you post screenshots of both your windows optional update page and also device manager
Yes, I have. It comes up with "You're up to date" after checking for updates.
That’s weird.
Install the Bluetooth driver from here
ColonelMicrowave
When I install the Bluetooth driver, for the MTK and MediaTek ones nothing happens when I "Extract all" and run "Asus Setup". For the Realtek one, I see console open for a split second and close immediately when I "Extract All" and run "Asus Setup", but nothing else. Is this supposed to happen?
It's just installing a driver.
