My 3000 squid Gaming PC I just purchased :p
Let me know what you think! Its been 5 years in the making, always went with intel in the past, but this time round I just couldn't do it! Just way too much negative feedback around Intel's 11th Gen 11900k CPU.
Let me know if I made the right decision :cry:
Product Description
NZXT H511 MID-TOWER GAMING CASE (WHITE) (460mm x 210mm x 428mm)
AMD Ryzen 9 5950X 16 Core CPU (3.4GHz-4.9GHz/72MB CACHE/AM4) ASUS® CROSSHAIR VIII HERO WIFI (DDR4, PCIe 4.0, CrossFireX/SLI) - RGB Ready!
12GB NVIDIA GEFORCE RTX 3080 Ti - HDMI, DP
1TB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 470MB/W)
1TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2500MB/sW) NOT REQUIRED
CORSAIR 1000W RMx SERIESTM MODULAR 80 PLUS GOLD, ULTRA QUIET
2x 120mm Black Case Fan (configured to extract from rear/roof) ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD) 10/100/1000 GIGABIT LAN PORT
what's it's uses, what monitor have you got resolution and refresh rate or make and model and what's the budget, and can you post the spec as described in the link below
PC is purely for gaming! and light admin MS office stuff, no streaming or content creation.
I have a 27inch LG 27UDG9P its only 60 hertz https://www.lg.com/uk/monitors/lg-27UD69P so looking to upgrade to 120hertz, 144hertz in the next 6 months or so.
Do you reckon my attached Gaming PC build will future proof me for 4k gaming when it becomes the norm if ever!
Thanks!
just posted it now couldn't attached to original post so had to post again https://www.pcspecialist.co.uk/foru...000-squid-gaming-pc-i-just-purchased-p.85431/
Those are the full spec SIR!
If you can copy and paste the full specs as in the link provided then we can see what we're working with.
A lot of us are mobile and can't use the configurator.
Can you post the full specs as in the link above?
ASUS TUF K1 Gaming Keyboard & M3 Mouse Bundle
Mouse Pad
PCS Mouse Mat - XXL
Standard Build - Approximately 14 to 17 working days
Welcome Book
Logo Branding
PCSpecialist Logo
2TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2700MB/sW)
Corsair H100i RGB PRO XT Hydro Series High Performance CPU Cooler
Mouse Pad
PCS Mouse Mat - XXL
Price: £3,143.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/pau64FkC!6/
For just gaming the 5950x isnt a great choice more for heavy production work the 5900x is a much better choice leaving you more budget for better storage options and a better case would opt for the h115i cpu cooler but its out of stock left the 3080ti in as you stated you would like a new monitor just be aware a decent 4k 144hz monitor ranges between £700-£1200
Mouse Pad
PCS Mouse Mat - XXL
Thanks for your input Jamie! I know tell me about the monitor its heartbreaking that monitors cost that much!
Personally I dont rate the 3080ti as being worth it for the money over a standard 3080 could add the savings towards that new 4k monitor dropping down to a 3080
Same build but with a 3080
Mouse Pad
PCS Mouse Mat - XXL
Price: £2,774.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/tZPT3WGKzM/
Most games at 4k your looking at a 4 -5 fps diffrence thats nearly £ 80 -100 a frame.
so if you buy the 3080 and in a months time you are playing assassins creed and nvidia said hey I can get you 2 more frames but that will be £380 extra for it then I would tell nvidia to get out of my house ;)
