Yes I'm learning fast and I did make the changes to both the NWC and the silver warranty. Thank you all.That looks like a good build to me! Just make sure you have the silver warranty, it's well worth the £5!
What a process! The image is perfectly clear. and this has got most of the important info so I'm sure it's okay. The main things worth checking that aren't in this photo is you've got the
WIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0 (£19) selected as the Wireless Network Card if you use WiFi at home, this will give you much better speeds. And, make sure you've removed the Anti-virus software, it's been known to cause issues for people!
If those changes have been made, you will have one sweet PC! Enjoy it and keep us updated, and of course if yo have any questions, we're always here!
I have had my computer now for a few days it is fast and runs very well, Now for the bad newsYes I'm learning fast and I did make the changes to both the NWC and the silver warranty. Thank you all.
Purchased from Amazon and loaded from MS store, I don't have a game pass. My MS account shows both of myHave you logged in to your xBox game pass account (asssuming that is where you purchased the game) as the game should then appear as available to you and able to download?
Where are you downloading it from - Steam / xBox / elsewhere?
I bought the 10 disk set from amazon then loaded them onto my old computer. It did not run well and toldSo how did you use to run it in the past? You dont need to have an xbox gamepass, but was it through the Xbox app?
This is the situation at the moment, I logged on to the xbox app and it said that I owned the fs2020 game and gave me theSo let me see if I understand this properly - you bought the CD version, loaded it on your last machine and used the code on the CDs to activate the game.
This didnt work, so you then bought a new code from Amazon for the download from the Microsoft Store.
You have logged then into the Microsoft Store and used this code to download the game and now its asking you for a code again and saying it (as in the second code for the download) doesnt work?
Has it downloaded anything? and therefore in the MS Store is it showing a 'Play' option button rather than an install or buy button?
Thanks for the reply, I have Installed avast security and nothing much else, 760 gig is free space so 240 used on hard drive.Can you copy and paste/post your full spec from the order page as looking back, there's been so many changes its hard to work out what you have got overall.
Thanks.
What else have you installed, if anything?
I am surprised that 760 gig has been used if this is all you have installed.
Perhaps a complete uninstall / reinstall is required.
does your current machine have a CD/DVD player with it?
I found the prog under apps and features it was150 gig so I uninstalled it and re-loaded during the night from xbox.OK - open the xBox game app on PC again.
On the left hand side you should see a list of games you own - in this case MS FS 2020
Check that it does not say Preparing / Installing / Downloading underneath that MS FS 2020 line - if it does then it still hasnt finished downloading or installing the game so you have to wait for that first.
When thats done or doesnt say anything, if you click play - what happens? is this when it crashes and does nothing?
If it crashes out - then I am afraid the first thing to try is to click the three dots to the right hand side and Uninstall.
then try to reinstall it after that and try again.
Not sure how to do that but I did put a screen shot on page 2 that I took with my camera but I don't have aMine takes ages to load too, its just such a big program. Can you post your full spec from your order page please
CPU AMD Ryzen 5 3600xMine takes ages to load too, its just such a big program. Can you post your full spec from your order page please
No the full spec as described in the link below:CPU AMD Ryzen 5 3600x
MB ASUS PRIME B550 -PLUS
RAM 16 GB Corsair VENGEANCE DDR4 3200 MHz 2x8
GC 8GB AMD RADEON RX 5500 XT
Storage 1TB PCS PCLe M.2 SSD
