Or if you can make the stretch, 3600! 3200 is the sweetspot but 3600 is ideal for some of the editing work you'll be doingSo AMD have yet to release a 1080p GPU for this generation, rumours say that they might be announcing the 6600 (XT) soon, which is likely going to be their 1080p card.
Nvidia GPUs are also better for streaming and editing due to specific encoding and CUDA cores, so at the moment I would suggest Nvidia for your uses.
Regarding the build I would suggest upping the RAM speed to 3200mhz. Ryzen CPUs benefit from fast RAM and 3200mhz is the sweet spot. Besides that, really solid build, hope it comes soon and we get a few photos of your setup! 😊
COOLERMASTER MASTERBOX TD500 MESH ARGB GAMING CASE![]() | |
Processor (CPU) | AMD Ryzen 7 5800X Eight Core CPU (3.8GHz-4.7GHz/36MB CACHE/AM4) |
Motherboard | ASUS® TUF X570-PLUS GAMING (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - ARGB Ready! |
Memory (RAM) | 32GB Corsair VENGEANCE DDR4 3000MHz (2 x 16GB)![]() |
Graphics Card | 12GB NVIDIA GEFORCE RTX 3060 - HDMI, DP |
1st Storage Drive | NOT REQUIRED |
1st M.2 SSD Drive | 500GB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 6900MB/R, 5000MB/W) |
2nd M.2 SSD Drive | 1TB PCS PCIe M.2 SSD (2000 MB/R, 1100 MB/W) |
DVD/BLU-RAY Drive | NOT REQUIRED |
Power Supply | CORSAIR 850W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET |
Power Cable | 1 x 1 Metre UK Power Cable (Kettle Lead) |
Processor Cooling | Corsair H115i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler |
Thermal Paste | STANDARD THERMAL PASTE FOR SUFFICIENT COOLING |
Extra Case Fans | NONE![]() |
Sound Card | ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD) |
Network Card | 10/100/1000 GIGABIT LAN PORT |
Wireless Network Card | WIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0 |
USB/Thunderbolt Options | MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS |
Operating System | Windows 10 Home 64 Bit - inc. Single Licence [KUK-00001] |
Operating System Language | United Kingdom - English Language |
Windows Recovery Media | Windows 10 Multi-Language Recovery Image - Unlimited Downloads from Online Account |
Office Software | FREE 30 Day Trial of Microsoft 365® (Operating System Required) |
Anti-Virus | NO ANTI-VIRUS SOFTWARE |
Browser | Microsoft® Edge (Windows 10 Only) |
Warranty | 3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour) |
Delivery | STANDARD INSURED DELIVERY TO UK MAINLAND (MON-FRI) |
Build Time | Standard Build - Subject to stock availability on pre-order products |
What monitors were you looking at? I’d suggest at least 1440p if not 1440p ultrawide for a 3070.Hi all. I wish they would build this haha I keep changing things. Now gone to the 3070 as I'm going to get a new monitor. Whats the best 2nd m.2 I've changed to the Intel but seen all the specs reccomend the pcs one. Also do I need the strix to future proof or is it not needed.
oh no i defo wont be upgrading the cpu for some time. i am prob going to get a high refresh 1440p monitor. prob ASUS TUF. thanks for your feedbackWhat monitors were you looking at? I’d suggest at least 1440p if not 1440p ultrawide for a 3070.
Both the PCS and Intel drives are perfectly good I wouldn’t be too fussed about which one you have, although I believe the Intel is a lot faster for only £3 more.
And nope, I wouldn’t say so. The TUF will be perfectly capable. If you plan to upgrade to the 5900X at some point then it’s something you might want to consider, but the 5800x is already a super powerful CPU 😂
