You might want to try testing each stick in turn to find out which one is flaky or you might just contact PCS and get the RAM replaced. Show them those results.
Sounds like one stick is dead. Try booting with each stick one at a time. Then call PCS Monday and ask for two matched sticks to replace them.Turned on, only 8gb showing up now. Enough for today. First the GPU. Now this. Heyho
Day 76 in the big brother house.
Another weekly BSOD
Help please. This time 0x000000ef
Just as an aside. I seem to get plenty of error / warnings. I say plenty. Not sure if that's normal
I've updated the link with the data dump and system details
fffffd0d`1266c5e8 fffff800`2607dd12 Unable to load image \SystemRoot\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_3784df9edffd3314\nvlddmkm.sys, Win32 error 0n2
nvlddmkm+0x17dd12
Thanks - I should've done that myself...I've merged your previous threads together also so we can see the history.
So.Thanks - I should've done that myself...
Looking back up the thread at your history, did you ever try running with one RAM stick? Flaky RAM can cause all sorts of errors...So.
PCS have already replaced the graphics card. So maybe the drivers? I’ll roll them back again and take your advice on the sound drivers. Begs the question, was it the drivers or the GPU?.
And of course. Massive thank you. Can’t imagine how long it takes you to go through the data and then the time to reply. Really appreciate it.
HiLooking back up the thread at your history, did you ever try running with one RAM stick? Flaky RAM can cause all sorts of errors...
Get PCS to replace both RAM sticks (I don't think you've done that already?). Point PCS at this thread, you need both replacing because you can't isolate which one is flaky.Hi
Yes, so run it individually. No error. Run it yesterday with both sticks. No errors. Run today with both sticks...
Error - I've attached the results on the latest.
Thanks again
Yep - PCS are kindly sending me new RAMGet PCS to replace both RAM sticks (I don't think you've done that already?). Point PCS at this thread, you need both replacing because you can't isolate which one is flaky.
And replacing the Zotec 3070 - The fan clattering noise is doing my nut!
However. Interestingly. I run the memtest86 again on the individuals, and then both. And they passed. Which they have before.
Though upon starting on my machine, it turned on a bit quicker and software seems to start up a bit faster. Indeed the BIOS start time on task, has gone down from 11.2 to 7 seconds? Strange!
The thing about Memtest is that it just stresses the RAM. The idea is to make it fail, if it does then the RAM is dud. But there's no way that Memtest can ever prove your RAM is good. If you ran it a thousand times and it passed 999 times and failed once - then it's dud.However. Interestingly. I run the memtest86 again on the individuals, and then both. And they passed. Which they have before.
