Mirror mirro what monors are better?
with a Nivida graphis card do i only want G sync and not free sync ?
You're right that freesync only works with AMD and Gsync only works with Nvidia. However even with a freesync monitor and Nvidia GPU you still get the high refresh rate. Gsync monitors are vastly more expensive at this end of the price range. I think the cheapest I've seen is ~£350, with many over £400.
never heard of Illyama before and they good or more aimed at the budge purchase?
They're fine, just another brand. Most brands have models aimed at a range of price points. I'd consider the merits of the specific model rather than the brand.
can i ask refresher on what a TN panel is compared to a IPS?
TN tends to have faster response time. IPS can have better colours and viewing angles. You won't find a cheap high refresh rate IPS panel though - and indeed at 1080p I think all 144hz monitors are TN rather than IPS.
can you my a monitor and get it not to use the speakers?
Yes you can select the sound output device in Windows.
