Not a bad idea I'd say.Think I will have to see what computer I end up getting in July and the graphics card I can afford. then see how it works with current monitor and start saving for Xmas for the more expensive screen.
No idea, looks like LG have some software you download for the monitor so maybe it's in there. It just looks like the same kind of thing you can already do on any screen in Windows with Aerosnap.How do you set up the split screens?
I've no idea I'm afraid, I can only suggest googling professional and user reviews. It's a bit more demanding than 1080p being 2560x1080 rather than 1920x1080 but should still be within the scope of a GPU like the RX 480 or the lower end of whatever AMD's vega line is.I this a good monitor ?
In terms of performance either is fine.if your going to be watching films/dvd s is it better to have a separate dvd drive or an internal one?
Another Odd qestion. but can you have computer monitor also to play VHS videos?
You'd need to convert the signal to the monitor, so scart lead to HDMI or DP, you can find them on Amazon or somewhere.
Hello, is this the sort of thing?
https://www.amazon.co.uk/AmazonBasi...1485695311&sr=8-5&keywords=scart+lead+to+HDMI
is a scart the same as a DVi?
