Case | PCS SPECTRUM RGB MID TOWER CASE |
Processor (CPU) | AMD Ryzen 7 3700X Eight Core CPU (3.6GHz-4.4GHz/36MB CACHE/AM4) |
Motherboard | ASUS® PRIME B450-PLUS (DDR4, USB 3.1, 6Gb/s) - RGB Ready! |
Memory (RAM) | 16GB Corsair VENGEANCE DDR4 2400MHz (1 x 16GB) |
Graphics Card | 6GB AMD RADEON™ RX 5600 XT - HDMI, DP, DX® 12 |
1st Storage Drive | 1TB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 470MB/W) |
DVD/BLU-RAY Drive | NOT REQUIRED |
Power Supply | CORSAIR 650W CV SERIES™ CV-650 POWER SUPPLY |
Drivers with OS fully updated? Could you paste all full specs, not just a short summary?Yes I have checked the mic settings and there all on max and I try go on obs and it has static in background but on old pc there was no static.
its really annoying because i bought this so id be able to stream games and because of this static in obs i have to turn dont mic so there no static then im really quiet my mic is fine on discord now but the mic is still quiet on obs due to me having to turn it down so theres no static but yet again there was no stactic on my old pc.
Case PCS SPECTRUM RGB MID TOWER CASE Processor (CPU) AMD Ryzen 7 3700X Eight Core CPU (3.6GHz-4.4GHz/36MB CACHE/AM4) Motherboard ASUS® PRIME B450-PLUS (DDR4, USB 3.1, 6Gb/s) - RGB Ready! Memory (RAM) 16GB Corsair VENGEANCE DDR4 2400MHz (1 x 16GB) Graphics Card 6GB AMD RADEON™ RX 5600 XT - HDMI, DP, DX® 12
Change to: 6GB NVIDIA GEFORCE RTX 2060 - HDMI, DP - VR Ready!1st Storage Drive 1TB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 470MB/W) DVD/BLU-RAY Drive NOT REQUIRED Power Supply CORSAIR 650W CV SERIES™ CV-650 POWER SUPPLY
all of mine are 100Interesting question had this problem today with a new computer for my daughter. If you go into sound settings and plug in your mic you will get the choice to go into advanced settings. For some reason the decibel level will be 0. Increase this to max along with the volume and it should work.
Power Cable | 1 x 1 Metre UK Power Cable (Kettle Lead) |
Processor Cooling | STANDARD AMD CPU COOLER |
Thermal Paste | STANDARD THERMAL PASTE FOR SUFFICIENT COOLING |
Sound Card | ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD) |
Network Card | 10/100/1000 GIGABIT LAN PORT (Wi-Fi NOT INCLUDED) |
Wireless Network Card | WIRELESS 802.11N 300Mbps/2.4GHz PCI-E CARD |
USB/Thunderbolt Options | MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS |
Operating System | Windows 10 Home 64 Bit - inc. Single Licence [KUK-00001] |
Operating System Language | United Kingdom - English Language |
Windows Recovery Media | Windows 10 Multi-Language Recovery Image - Unlimited Downloads from Online Account |
Office Software | FREE 30 Day Trial of Microsoft 365® (Operating System Required) |
Anti-Virus | BullGuard™ Internet Security - Free 90 Day License inc. Gamer Mode |
Browser | Microsoft® Edge (Windows 10 Only) |
What mic are you using? Is it USB or jack?i dont know a whole lot about computers but i checked and the mic driver it is up to date but the main problem i have now is that there is static in the background of obs which i can get rid of by turning the mic down on obs but then i am too quiet.
i use a jack its a headset mic but had no problem with it on obs on my old computer.What mic are you using? Is it USB or jack?
Which headset is it?i use a jack its a headset mic but had no problem with it on obs on my old computer.
Do you know the make and model?View attachment 22910thats the headset i have, it wasnt alot.
