I'm looking for a new gaming PC and it's been quite a while since I last looked at specs, so could use some advice to avoid later regret.
Budget is £1200 ish. Main requirements:
3) Not interested in overclocking - I don't have the time, patience, knowledge to do anything except press the on button. Might mean a better CPU is sensible, in which case the new 5xxx CPUs may be a good fit.
4) Quiet as possible.
Point 1 above may be completely moot if bargains appear during Amazon/Black Friday for a new 27 inch 1440p monitor. In this case, I'm likely to be running a mix of 1080p and 1440p for games, accepting lower settings for the latter.
All of this led me to the spec below.
The only thing I would highlight is the CPU: 3600 seemed a natural pick but the newer CPUs are tempting. I'm not in the habit of upgrading often (my last PC may as well have had the case welded shut) so a better CPU may give more longevity. Am I right in thinking the closest to a 3600 is the 5600X? And is that likely to need a better cooler?
I've trimmed the text below a tad to remove the fluff. Thanks in advance for any feedback.
Price: £1,178.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/9e5hHaaMSq/
- 1) Maxed 1080p for games, to work with my current monitor (a really old Asus VG236). That runs up to 120Hz but only via dual link DVI so assume I am going to need a converter for DP.
Processor (CPU)AMD Ryzen 5 3600 Six Core CPU (3.6GHz-4.2GHz/36MB CACHE/AM4)
MotherboardASUS® TUF X570-PLUS GAMING (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - ARGB Ready!
Graphics Card6GB NVIDIA GEFORCE GTX 1660 SUPER - HDMI, DP - GeForce GTX VR Ready!
1st Storage Drive1TB Samsung 870 QVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
1st M.2 SSD Drive500GB SEAGATE FIRECUDA 520 GEN 4 PCIe NVMe (up to 5000MB/R, 2500MB/W)
Power SupplyCORSAIR 750W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor CoolingSTANDARD AMD CPU COOLER
Wireless/Wired NetworkingWIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
