Looking For Advice
GCUK
Haven't had a PC in a while so out of the loop with what is good etc. My budget for the PC itself is around £1200 to £1300, I will look at all the extras at a later date.
It will be mainly used by my son who is 11 and getting into PC Gaming but I will also be getting back into it with Battlefield etc. The PC would be for a mixture of gaming, photo editing and potentially some light video editing, but not essential. I will get a monitor to match the PC but like I say that will be later but any suggestions are welcome.
ASUS® PRIME B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
16GB Corsair VENGEANCE DDR4 2400MHz (2 x 8GB)
256GB PCS 2.5" SSD, SATA 6 Gb (500MB/R, 400MB/W)
CORSAIR 650W CV SERIES™ CV-650 POWER SUPPLY
STANDARD AMD CPU COOLER
Standard Build - Approximately 19 to 22 working days
Price: £1,284.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/TkPWqvjytN/
Steveyg
Hi mate, you're compromising in some key areas that will yes work but in a few years could run into problems or bottles necks
I've readjusted the build below and although it's out of the budget it's a much more balanced system. The problem is that there seems to be few options for GPU selections in stock making it difficult to get something right on budget
The below is a very very solid 1440p build though
ASUS® TUF GAMING B550-PLUS WiFi (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
NOT REQUIRED
Price: £1,417.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/CqherSNy0m/
sck451
What will you be looking to spend on a monitor? You will need to match the build to the monitor. There's no point choosing a 1440p graphics card like the 3060 Ti if you're going for a 1080p monitor. A 1080p monitor starts at £150, whereas 1440p monitors start near £300.
Steveyg
There's not much else to choose on the configurator mate except the 2060 and the price difference between that and the 3060Ti at the minute you might as well go for the 3060Ti
GCUK
Haven't decided on monitor yet but I will buy to match the PC spec. Agree with what your saying it's like buying UHD to watch on a CRT TV lol
Steveyg
What's the performance of the 6600 XT like compared to the 3060Ti?
It's significantly less powerful, the 660XT is a 1080p GPU and a good one.
The 3060Ti is a 1440P GPU which is almost double the amount of the pixels. It has a lot more beef, I have one and I'm running almost everything at 144FPS at 1440p
sck451
If you're going to be getting a 1080p monitor, get the 6600 XT. If you're going to be getting a 1440p monitor or if you're going to be doing heavy video editing work, the 3060 Ti would be the best choice.
normally its easier to do it the other way round, match the build to the monitor rather than monitor to the build
GCUK
I would be getting a 1440p monitor, just haven't decided which
GCUK
So I've tweaked my original build idea taking ideas from posts above. It's still a bit over budget so can anyone see any small areas I could tweak without sacrificing too much performance? Thanks again.
ASUS® TUF X570-PLUS GAMING WIFI (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - RGB Ready!
1TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2500MB/sW) (Special Offer)
PCS FrostFlow 100 V3 Series High Performance CPU Cooler (AMD)
LED Lighting
50cm RGB LED Strip
NOT REQUIRED
Price would be £1481
Steveyg
LED Lighting
50cm RGB LED Strip
NOT REQUIRED
I'd say you're over speccing on the motherboard. The B550 is excellent and more than enough for the 5600x
I also doubt you'll see much of a difference in cooling between that Frostflow and the Standard AMD option. The 5600x isn't an overly hot chip so the standard cooler works quite well
Also the Silver Warranty is a bargain for a fiver mate
Case selection is good if you prefer that one
If you wanted to stretch your budget a little more the below changes would give you much better longevity
512GB INTEL® 670p M.2 NVMe PCIe SSD (up to 3000MB/sR | 1600MB/sW)
NOT REQUIRED
Price: £1,484.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/3HUhuD8Xyp/
LED Lighting
50cm RGB LED Strip
NOT REQUIRED
have you got the configuration link for this
Never mind @Steveyg has highlighted the areas i was going to change
GCUK
Apologies I posted from my phone and couldnt see the code.
NOT REQUIRED
Price: £1,458.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/wvTd!ZXYYF/
Dropping the motherboard and changing the PSU to the RXm gives you this
NOT REQUIRED
Price: £1,422.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/tStANkxqQK/
sck451
What will your budget be for the monitor? The G5 is excellent value at the low end of the 1440p gaming market, but there are other superior options if you don't mind spending £100-200 more.
GCUK
I think the G5 would be sufficient enough to be honest.
