Liquid or not
PawWoj
Hi there, just a quick question about these 2 configs. Is the Liquid cooling worth the extra 1K? or should i stick with air?
Air:
Case COOLERMASTER MASTERCASE SL600M GAMING CASE
Overclocked CPU Overclocked Intel® Core™ i9-10940X 14 Core (3.30GHz @ up to 4.6GHz)
Motherboard ASUS® ROG STRIX X299-E GAMING II: ATX, USB 3.2, SATA 6 GB/s, Wi-Fi AC - RGB
Ready
Memory (RAM) 32GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (2 x 16GB)
Graphics Card 11GB ASUS ROG STRIX GEFORCE RTX 2080 Ti - HDMI, DP
1st Storage Drive NOT REQUIRED
1st M.2 SSD Drive 2TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
Power Supply CORSAIR 750W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor Cooling Corsair H115i PRO Hydro Series High Performance CPU Cooler
Wireless/Wired Networking 10/100/1000 GIGABIT LAN PORT (Wi-Fi NOT INCLUDED)
USB/Thunderbolt Options MIN. 2 x USB 3.0 & 6 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Operating System Windows 10 Professional 64 Bit - inc. Single Licence [MUP-00003]
Warranty 3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour)
Total Order Price Ex VAT £3,081.67
Total VAT (20%) £616.33
Total Order Price £3,698.00
Liquid:
Case LIAN LI O11DYNAMIC XL ROG CERTIFIED GAMING CASE
Custom Liquid Cooling Kit Liquid Series RGB Lian Li PC011D – EK
Tubing Clear Hardline PETG Tubing (Bent/Metallic Fittings)
Graphics Card Cooling GPU Water Block - For One Graphics Card!
Coolant Colour Mayhems Pastel Pure Black
Motherboard ASUS® ROG RAMPAGE VI EXTREME ENCORE: DDR4, 6Gb/s, CrossFireX/SLI, Wi-Fi
AC - RGB Ready
Power Supply CORSAIR 1000W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Braided Power Supply Cables CORSAIR Premium Individually Sleeved PSU Cable Kit Pro - Red/Black
USB/Thunderbolt Options MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Warranty 3 Year Platinum Warranty (3 Year Collect & Return, 3 Year Parts, 3 Year labour)
Total Order Price Ex VAT £4,064.17
Total VAT (20%) £812.83
thanks for any advice.
Charlas
Liquid is quieter, and sometimes (not always) cooler.
If interested have a look at some of the videos on cooling over on gamers nexus (YouTube) Air is usually able to cool as well as liquid, but liquid looks cooler (personal opinion) and almost always quieter than forced air cooling.
PawWoj
This build will be for gaming, 3d rendering and engine work, potentially streaming further down the line
Charlas
For the most part, then it will be an aesthetic or acoustic based decision for you. If you like RGB and are going to put it in a clear sided case, then water cooling will look cool. If enclosed case you can't see, then I'd save the money and go air, or perhaps AIO on the CPU as a half and half sort of thing.
PawWoj
As a statement Liquid does look cooler, but i was more interested in the cooling potential of a GPU and CPU in a closed loop over air cooled under heavy load, and weather the benefits are worth the extra £££
Charlas
Lots of benchmarks around (have a look at LTT / Gamers Nexus on YT) but the downlo is that IF liquid cooling does save you the temperature, it's not a lot as a rule, and it's rather done nowadays for the look.
The take away they both had was water can cool better, but for their day to day builds they would use air, it's less maintenance, less hassle, less to go wrong.
Closed loop coolers are so effective these days and so much cheaper that custom loops are really only used for stuff like rendering systems where gpu is on 100% load for extended periods, but even then, I’d just buy a hybrid GPU with a closed cooler on it and save a fortune.
PawWoj
I didn’t see an option in the custom setup for a closed loop gpu cooler, unless I missed something?
As for the case, is that a good choice for the air cooled spec? I watched a lot of the gamers nexus reviews and it’s seems good, is there a better choice anyone would recommend?
You’d just source your own and fit yourself and select “none, I have my own graphics card” in the configurator.
Ok thanks, I’ll look into it, any advice on the case?
If you were to do away with custom loop cooling, then it opens up a whole realm of better builds.
AMD would absolutely walk all over anything Intel have to offer, just literally destroy it, about double the multithreaded performance whilst being better in gaming also as much higher base clocks. I would do an entirely different build if it were mine.
PawWoj
I guess I just auto pilot to Intel because of past bad experiences with AMD, but I guess im out of touch!
I made this configuration just before you posted, looks the same just has the threadripper, so on the same page:
Overclocked AMD Threadripper 3970X 32 Core (3.7GHz @ up to 4.3GHz)
ASUS® ROG STRIX TRX40-E GAMING (DDR4, Wi-Fi 6, CrossFireX/SLI) - RGB Ready! 32GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (2 x 16GB)
NOT REQUIRED
NOT REQUIRED
CORSAIR 1000W RMx SERIESTM MODULAR 80 PLUS® GOLD, ULTRA QUIET
CoolerMaster MasterLiquid ML360 RGB TR4 High Performance Liquid Cooler STANDARD THERMAL PASTE FOR SUFFICIENT COOLING
Charlas
@Scott @SpyderTracks Would a Threadripper be more beneficial here given the 3-D rendering use?
All depends on the package, more cores is as a rule always better 😁
But sometimes too much is just a waist if its not gonna be used, but only the user will know specific use cases and what the software is capable of, also remember you will probably need windows pro, not home for a Threadripper build.
Charlas
Oh side note, Threadripper + gaming are not necessarily great friends, just so you know, almost always benchmark Below ryzen 3000 parts on same setup otherwise (especially 1% and 0.1%, due to cache latency)
I would also be looking at the Ryzen 3000. You would probably be fine with the 3900X but the budget is there for the 3950X and it will smash your requirements. I don't think you need a TR4 build to be honest, I think that would be overkill on the processing grunt without focusing on the gaming grunt.
This is extremely lavish. A dream build to be honest. You don't need the Strix items, and the GPU is hugely over-priced, but you know EXACTLY what you are getting so it's probably worthwhile.
You don't need the 1000W PSU, so if the 750 or 850 RMx come into stock, just swap them over.
With the storage, 1TB is your primary, the 2TB drive is for fast loading games and a scratch/cache drive. I would partition the 2TB drive personally so that you can have 500GB for cache/scratch and 1.5TB for games/other stuff. Will be less confusing that way.
FRACTAL MESHIFY S2 BLACKOUT TEMPERED GLASS
AMD Ryzen 9 3950X 16 Core CPU (3.5GHz-4.7GHz/73MB CACHE/AM4)
ASUS® ROG STRIX X570-F GAMING (USB 3.2 Gen 2, PCIe 4.0) - RGB Ready!
NOT REQUIRED
2nd M.2 SSD Drive
NOT REQUIRED
Firefox™
Standard Build - Approximately 15 to 18 working days
Price: £3,729.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/Ts7TA5tQvy/
Just to add, I'm very suspicious and wary of all "tests" like this. Linus did a similar test.
IMO they are leaving the cases open and not allowing proper stressing soak to occur. There is just no way an air cooler would get close to the H115i on my 9900k. Even buying the biggest chunk of metal to hang off the motherboard wouldn't keep it in check. The air coming out of those coolers is hot.... then swirling around the case. It's not good for the GPU, the CPU will heat soak and the motherboard will take the strain of the hunking big chunk of tin.
Linus was of the very same opinion and said exactly the same things...... but his "day rigs" all have AIOs in them. Every system he builds has an AIO in it.
Given my actual hands on experience with the differences in the cooling options, there's something VERY fishy going on.
PawWoj
NOT REQUIRED
2nd M.2 SSD Drive
NOT REQUIRED
Firefox™
Thank you Scott, appreciate the help.
I will probably go for the ASUS Crosshair VIII Hero instead of the ASUS® ROG STRIX X570-F because of the extra ports and minus the integrated GFX which has caused me headaches in the past.
Is there any particular reason you would stick with the STRIX motherboard?
