Laptop Spec / Purchase Feedback Please
Stefan01!
Hello all,
I'm new to the forum.
I'm looking to buy a laptop primarily to get into video editing as a career option. I'll be using Adobe Premiere Pro as the main editing program.
I also be using After Effects, Photoshop, and Illustrator - so I know I need something that can deal with them.
I've gone for a Laptop as I want to be on the go.
I'm not really clued up on computers and the specs needed tho - only that the CPU, Graphics Card and RAM is important.
I wondered if I could get feedback over the below spec of a laptop I configured, and to see if it would be good enough for the above, or if its overkill.
I would want the laptop to be good/ powerful enough to last for a number of years.
my budget is £1800 inc VAT (as you'll see its slightly above)
Thanks in advance......
Promotional Item
Get Alan Wake 2 with Select GeForce RTX 40 Series!
Recoil Series: 17" Matte QHD 240Hz sRGB 100% LED Widescreen (2560x1600)
Intel® Core™ i9 24 Core Processor 13900HX (5.4GHz Turbo)
32GB Corsair 4800MHz SODIMM DDR5 (2 x 16GB)
NVIDIA® GeForce® RTX 4070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
1TB CORSAIR CORE XT MP600 NVMe PCIe M.2 SSD (up to 5000 MB/R, 3500 MB/W)
AC Adaptor
1 x 280W AC Adaptor
Recoil Series Integrated 99WH Lithium Ion Battery
GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6E AX211 (2.4 Gbps) + BT 5.3
1 x THUNDERBOLT 4 PORT + 3 x USB 3.2 PORTS
RECOIL 17 SERIES RGB BACKLIT UK KEYBOARD
INTEGRATED 1MP HD WEBCAM
Chassis
TongFang GM7PX7N (8GB RTX-4070, i9-13900HX, 240Hz QHD)
Welcome Book
Price: £1,837.00 including VAT and Delivery
Tron1982
Hello, so, technically, this is a pretty good spec' I'd say.
But the recoil is made to be use with the optional cooler ... (I don't like this that, to be fair ...)
I don't really know what the SSD corsair worth ...
So, i propose you an other configuration, that is, too, a little bit over 1800£
Because, i add the golden warranty (instead of the silver one) and the dead pixel guarantee
I prefer have a good protection and not use it than not having it and need it ... (my apologies if this sentence don't make sense in english, in french, it does, i promise :D)
Anyway, this is what i propose you, it's more or less the same with those difference
- different chassis that is a little bit smaller (16" instead of 17", but with a thermal solution a little bit better for a "stand alone" experience (ie a vapor chamber)
- same port selection (plus a mini DP)
- a smaller battery
Ionico Series: 16" Matte QHD 240Hz sRGB 100% LED Widescreen (2560x1600)
Intel® Core™ i9 14 Core Processor 13900H (5.4GHz Turbo)
AC Adaptor
1 x 230W AC Adaptor
1 x Ionico Battery 73WH
VAPOR CHAMBER ADVANCED COOLING
GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6E AX211 + BT 5.3
IONICO MULTI COLOUR BACKLIT UK KEYBOARD
Microsoft® Edge
INTEGRATED 2.0 MP FULL HD WEBCAM
Dead Pixel Guarantee
30 Day Dead Pixel Guarantee Inc. Labour & Carriage Costs
Chassis
Clevo PE60RNE-G (8GB RTX-4070, i9-13900H, AX211, QHD 240Hz sRGB 100%, Blank KB)
Price: £1,862.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/ionico-16/nzf4wMvEry/
If you don't like this configuration (i can understand), i'd add the golden warranty and the dead pixel guarantee to your config
I hope this will help you
