Laptop for photo/Video editing
garfor
I've specced a Laptop for heavy Photoshop/Lightroom and Premiere Pro use.
It's for serious hobbyist use with a Lightroom catalogue of 750,000 images and I want to start shooting 8K/4K video with my Canon R5 camera rather than the HD/low bitrate 4K that I currently shoot. My last computer was a PCS desktop (2016 bought) with I7-7700K, 32 GB DDR4 3000 ram, GTX 970 graphics card, 256GB M2 SSD, 480GB 2.5" SSD and 1 x 5tB and 2 x 8Tb hard drives. The computer still works ok for photography but really struggles with video. I'm not sure it's possible to upgrade it to a better for video standard and also like the though of a new laptop.
I was hoping to keep below £2000 but ended up with the spec below. Just not sure if I have over specced or under specced.
Ionico Series: 17.3" Matte QHD 165Hz sRGB 100% LED Widescreen (2560x1440)
AMD Ryzen™ 9 Eight Core Processor 5900HX (3.3GHz, 4.6GHz Turbo)
32GB Corsair 3200MHz SODIMM DDR4 (2 x 16GB)
NVIDIA® GeForce® RTX 3070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
4TB CORSAIR MP400 NVMe PCIe M.2 SSD (up to 3480 MB/R, 3000 MB/W)
2TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2700MB/sW)
AC Adaptor
1 x 230W AC Adaptor
Ionico Series Integrated 91WH Lithium Ion Battery
GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6E AX210 (2.4 Gbps) + BT 5.0
1 x USB 3.2 PORT (Type C) + 3 x USB 3.2 PORTS
IONICO 17 SERIES RGB BACKLIT UK KEYBOARD
Laptop Cooling Stands
CoolerMaster NotePal L2 Laptop Cooler, up to 17.3 inch
INTEGRATED 1MP HD WEBCAM
Chassis
TongFang GM7ZN7P (8GB RTX-3070, R9-5900HX, 165Hz QHD, Blank KB)
Price: £2,401.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/ionico-II-17/KFUytg7ss4/
Cheers
Gary
Tron1982
Hey, hello
What are your need for video editing ? (in raw power)
Do you need a 17" or a 15" ?
Do you work on a different monitor or the screen on the laptop ?
Will you use it on battery or plugged ?
Wath's your maximum budget ?
Otherwise, this is the ionico i'd go for
2TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
AC Adaptor
1 x 230W AC Adaptor
Dead Pixel Guarantee
Chassis
Price: £2,446.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/ionico-II-17/NYGhYdvuhw/
garfor
Hi
Thanks for that.
I plan on using the Laptop screen for most of the editing. Video editiing will be 8K raw or 8K all-I that is then downsized to 4K. Most of the time the laptop will be plugged in. I want it to act as a desktop replacement. I was hoping to come in at about £2000 but could stretch to an higher amount if needed.
Cheers
Gary
Tron1982
Hey,
I'm not a pro at video or photo editing, so you may want to take what i say with a pinch of salt
So, i was looking at what raw spec is needed for 8K video editing, and, clearly, with a laptop, i will be hard to find something at this range of price (2kish) ...
You need the best gpu and cpu available, a good screen (you may want to pay for an external monitor ^^") and as much ram you can get ...
And so, this is the best config' i'd go for :
(because i'm not sure the ionico will be able to handle this kind of heavy workload ^^")
First choice : expensive and heavy laptop, but you have everything you need inside it (at least, for what i saw on google)
Recoil Series: 17.3" Matte QHD 165Hz 100% sRGB LED Widescreen (2560x1440) + G-Sync
Intel® Core™ i9 Eight-Core Processor i9-11900K (3.5GHz) 16MB Cache
128GB Corsair 2666MHz SODIMM DDR4 (4 x 32GB)
NVIDIA® GeForce® RTX 3080 - 16.0GB GDDR6 Video RAM - DirectX® 12.1
AC Adaptor
2 x 280W AC Adaptor
2 x 1 Metre UK Power Cable (Kettle Lead)
Recoil Series Detachable 8 Cell Lithium Ion Battery (97WH)
2 Channel High Def. Audio + SoundBlaster™ Atlas & Super X-Fi
2 x THUNDERBOLT 4 + 1 x USB 3.2 (TYPE C) + 3 x USB 3.2
PER-KEY RGB BACKLIT UK KEYBOARD
Chassis
Clevo X170KM-G (165Hz QHD, G-Sync, Blank KB)
Price: £4,056.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/recoil-V-17/rayVZyRgnV/
second choice : everything you need inside the laptop, but you need an external screen (to be honest, i think this is better value for money even if you have less ram and a smaller screen)
Destian Series: 15.6" Matte Full HD 240Hz 72% NTSC LED Widescreen (1920x1080)
64GB Corsair 2666MHz SODIMM DDR4 (2 x 32GB)
8TB Samsung 870 QVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
AC Adaptor
1 x 230W AC Adaptor
Destian Series Detachable 6 Cell Lithium Ion Battery
1 x USB 3.2 PORT (Type C) + 2 x USB 3.2 PORTS + 1 x USB 2.0 PORT
15" DESTIAN SERIES UK KEYBOARD
Chassis
Clevo NH55VRQ (8GB RTX-3070, 240Hz N7, Blank KB)
Price: £2,995.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/destian-15/Eu9!T0QFW3/
So, it's up to you, but maybe at this price, you would like to go for a classical monitor/tower combo ^^"
But this is up to you ^^
