The suspense is killing me
Me too.
Intel drivers. "Intel Chipset Drivers" to be exact.
These are the ones that CLEVO themselves supply, DO NOT install them. IF you have them installed, best advice: do a fresh install and throw those particular drivers away.
Now to clarify things:
I've done a complete wipe of the drive and installed Windows 8 again, only things installed are the wifi drivers and Microsoft Updates and pretty much nothing else, (not driver wise anyway).
I've not had a single issue, I cannot even replicate the disconnections after using the laptop for a couple of days. So I'm led to believe that the ICD's are conflicting with other stuff. Bad thing is, they can't actually be un-installed, so it's best to start fresh IMHO.
If others could try this to confirm this I would be greatly appreciative, it might be possible to solve a LOT of peoples problems with this.
Note: Router is 100% good, so that is out of the equation.
So you've not even installed the Intel-supplied chipset drivers? Just what came with Windows 8?
