Can you get buyers remorse after two years?Rakk is now happy about deciding to wait and not get a 12th Gen Intel, is looking at numbers and grinning(my wallet may not be but that's another thing entirely)
12th gen was only from Winter, not even a yearCan you get buyers remorse after two years?
I don't think there's a case to be made for 240mm coolers. They are certainly not superior to a good air cooler. If air coolers are no longer practicable (and I have my doubts about that, personally, but we'll see), then 240mm has had its day too.Also, with TDP steadily increasing are the days of air CPU coolers gone, even with beasts like Noctua or BeQuiet? Will 240 AIO be the min for adequate thermals. No mention if 7600x comes with a stock cooler for example
To be honest at this rate I'll probably wait til the new year anyways (ie not buying a PC just before Christmas) as it'll be better for me then anyway, by which time Raptor Lake should be out so I can compareWill you wait a few more weeks to see how raptor compares? Or you think 7000 will still better it?
Hey, I've got a 9700k currently, I'm goodCan you get buyers remorse after two years?
The TDP for the 7600X is 105, same as the 5900X, and I think most people would recommend a 280 or 360 AIO for that, or at least a Noctua NH-D15 or similar. And if we need to go with that level of air cooling, that might limit people's choice about RGB RAM, given the higher profile.I don't think there's a case to be made for 240mm coolers. They are certainly not superior to a good air cooler. If air coolers are no longer practicable (and I have my doubts about that, personally, but we'll see), then 240mm has had its day too.
For an AIO, 280mm is the only sensible option in my book.
I'd personally prefer to wait for real world testing rather than relying on the TDP reported by manufacturers...The TDP for the 7600X is 105, same as the 5900X, and I think most people would recommend a 280 or 360 AIO for that, or at least a Noctua NH-D15 or similar. And if we need to go with that level of air cooling, that might limit people's choice about RGB RAM, given the higher profile.
Fair point, I'm using the manufacturers numbers to compare like with like in the absence of real world data.I'd personally prefer to wait for real world testing rather than relying on the TDP reported by manufacturers...
I'd happily take AMD's word for their power consumption, but double anything Intel claims.Fair point, I'm using the manufacturers numbers to compare like with like in the absence of real world data.
Not wanting to re-litigate air cooling vs water cooling, merely to say that 240mm radiators are quite possibly also obsolete in this new era.In an actual case, and not in bench testing, I would argue that they are. Not in general of course, but good ones like the Corsair H100 series, or even the coolermaster lite offerings.
Sustained use sees air coolers heat-soak far quicker than any AIO water cooler.
Denz likes it when others talk about themselves in the third person. Denz is probably a bit weird like that.Rakk is now happy about deciding to wait and not get a 12th Gen Intel, is looking at numbers and grinning(my wallet may not be but that's another thing entirely)
If PCS had the option to whack a H170i Capellix in my build I probably would have taken it. Seeing 3 140mm fans powering at the top of my case might have been the final push to order that tempered glass side panel. Still though, must be a monster pump to push the fluid round, so I guess it might be a noisy boy.I do understand, but my point is there actually isn't that much in it between a good 240mm cooler and a good 280mm cooler. The main difference is acoustics thanks to the larger fans.
The actual cooling potential is typically 20w of difference between the fan profiles (240-280-360).
I would always choose the 280 over any, as long as the requirements were met, as it's the best acoustics available. If space is a limitation I would have no issues cooling most chips with a H100i, the customers just need to consider the noise when at full chat.
The worst of the bunch acoustically is the 360mm though. Those can get super noisy with the small fans.
They don't really go much bigger as we are pretty much at the limit of what can be dissipated from the pump head now. Otherwise there would be more significant gains between the sizing. The radiator isn't really the limiting factor.
Don't Corsair offer remote pumps yet, so you can mount it on the outside of your house?If PCS had the option to whack a H170i Capellix in my build I probably would have taken it. Seeing 3 140mm fans powering at the top of my case might have been the final push to order that tempered glass side panel. Still though, must be a monster pump to push the fluid round, so I guess it might be a noisy boy.
Config page should go live 15th September.Any idea when PCS would usually update the website configuration so we can consider spec and prices? Ahead of release or is there a delay until motherboards and SSDs all become available and they test etc? Or is it a case of patience and come back end of Sept...
Pre orders go live on 15thAny idea when PCS would usually update the website configuration so we can consider spec and prices? Ahead of release or is there a delay until motherboards and SSDs all become available and they test etc? Or is it a case of patience and come back end of Sept...
I don't think they do too much with the pumps to be honest. I've long thought this is what holds them back rather than the rad surface area.If PCS had the option to whack a H170i Capellix in my build I probably would have taken it. Seeing 3 140mm fans powering at the top of my case might have been the final push to order that tempered glass side panel. Still though, must be a monster pump to push the fluid round, so I guess it might be a noisy boy.
